01-17-2003, 11:34 PM
Garage Rocker
Had a problem slamming 911 body, how's this look?
I slammed my 911, had to dremel at the rear wheel wells quite a bit, and my PCB is being held down by electrician's tape. It looks way cooler now though. You think?
Here's the problem, the back had hairline cracks where the screw that holds the motor in smashes against it. I was afraid the plastic would chip away when I cutthe slot, and it did.
I covered it with a little license plate. Does this work? I know it's a little large, but I had to cover my mess.
01-18-2003, 09:50 AM
You can't beat it.
I think the license plate should be removed because it's too big and it should be replaced with modelling putty in the cracks. Smooth it out, so it blends in.
My Garage: One Lamborghini Jota, Murceilago, Diablo, and a Countach.
One Ferrari Enzo.
One Porsche 911 GT2s, and 1 911 Turbo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
And 4 dozen Toyota Supras, 6 Skylines, and a Hino Blue Ribbon Bus from the Keisei Line.
01-19-2003, 02:14 PM
Actually, they suck^
not bad... it looks better since its lower... take off the plate and put some putty in the cracks- it'll look way better
01-19-2003, 04:41 PM
I had the same problem trying to lower my Civic and ended up throwing the bod away it was soo hacked up.. Its hard lowering a ZipZap for the first time.. I think RadioShack needs to produce a body that comes with enough room for lowering like a Suburban or Escalade body..
01-21-2003, 04:26 PM
that looks pretty sharp except for the black lines
