Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Wild Char-G
Old 12-02-2002, 07:04 AM
e_lm_70 e_lm_70 is offline
Send a message via Yahoo to e_lm_70
Wild-G has Stearing weels ?
Looking from the pics on the net it look like that the Wild has no stearing weels, It look like there is a rear motor stearing system similar to what it is in use on Digi-Q!
Am I right ?
Old 12-02-2002, 03:02 PM
Senshi Senshi is offline
yea it drives pritty much the same way as a digi q but its more controlable because it does go as fast
Old 12-03-2002, 01:22 AM
Bad news
Car must stear with weels not my traction diff !
I will probably don't buy ... or I will need to mod it
Old 12-03-2002, 04:25 PM
i ment to say that it is more controlable then a digi q. the stearing feels just like a normal bit char-g. its alot of fun
Old 12-11-2002, 02:22 PM
hangbot hangbot is offline
Thumbs up
it's true - you really don't notice the rear wheel steering. It actually turns pretty tight and without a hitch!
I recommend them. They're really fun...and different from the norm of Bits
______________________________
Automodelista: 3.8, 150mah, spring sus.
Wild-G: Raise Tiger w/3.8@the wheels & 2.2@the plow, 150mah
Lancer EVO: 3.0, 150mah, drift set
Hummer shell: 3.8, 150mah, spring sus.
Old 01-14-2003, 08:15 PM
arceeguy
How does the "rear wheel steering" work?
The WCG has two motors, one for the "gimmick" arm, and one for propulsion - right? Some pictures of the guts would be cool!
Old 01-15-2003, 02:12 PM
Ganpachi Ganpachi is offline
It uses magnets.. when you want to turn left or right, magnets pull a metalrod left or right, and it's got a gear which will engage to reduce power to one side.
This is just speculation as I wasn't really looking at the mechanism when I opened up my WCG to solder on a new antenna and install new battery.
way better stearing maxx4life ZipZaps Monster Truck 58 03-28-2006 07:31 PM
Drop the Slop... Stearing that is Cyfiawnder XMODS Parts and Hop-Ups 11 01-07-2004 02:43 PM
Wild & Booster & 4CH Bit controler e_lm_70 Wild Char-G 5 01-29-2003 08:15 AM
Short range for Wild Char-g??? DisfourDan Wild Char-G 4 01-14-2003 06:06 PM
For those of you who want a 4x4 wild char-g DisfourDan Wild Char-G 4 01-05-2003 10:54 PM
