Old 01-13-2003, 08:58 PM
BabyKiller's Avatar
what battery???
i was wondering what would be a apportpreate battery for the 3.8 r-spec(dual cell i dont know how to install if u suggest please post a link with instructions)
Old 01-13-2003, 09:08 PM
shanly
www.questformadness.com
Old 01-13-2003, 09:15 PM
BabyKiller's Avatar
ok let me put it this wayi want to build a customized drag racer heres the parts i have/think i should get for this
3.8r-spec motor
duel cell/high compacity battery
hard tires
(need to know what would be the best gear set for my rig)
if i can how do i add turbo
BabyKiller's Avatar
oh and any other suggestions to make it faster im willing to go all the way
Old 01-13-2003, 09:17 PM
takumi_drifto's Avatar
takumi_drifto takumi_drifto is offline
DriFt OnLi
Send a message via AIM to takumi_drifto Send a message via Yahoo to takumi_drifto
ummm my drag car has a 3.8 motor, duel cell mod, wheely tail bar... orange kit back tires, hard front tires, and thats about it soo far.
DriFT_
Old 01-13-2003, 09:25 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
I use a NiMH battery in the Z, and two of them in the ZipZap.
Old 01-14-2003, 06:31 AM
BabyKiller's Avatar
ummm what is the highest volt single baterry and where can i fin it here is so far what i have come up with(oh and i still need that info on the gears which should i get).also is the
3.6 nihm battery 1 or 2 batterys?
Old 01-14-2003, 08:03 AM
funkymonkey funkymonkey is offline
BabyKiller,
Nimh's are 1.2V. You can combine, 1, 2 3, or even 4 to make up to 4.8V. Max the receiver board can take is 5V.
The easy way to dual cell or triple cell is to use 2 or 3 nimh button cells which you should be able to squeeze in. You'll have a little less capacity than normal, but a small price to pay for the easyness of the mod. See the 'Laymans guide to dual cell'
Others talk about Lithium-Ion or Lithium Polymer batteries, these are 3.7V. For a start thats similar to triple cell so would probably only be useful for drag racing, second, you need a special charger, and third, you cant let the receiver PCB discharge it to nothing like you normally do, it kills the battery.
Never let your Li-Poly go below 3.0V.
Easiest as I say, is button cells. They're dirt cheap too.
Old 01-14-2003, 08:08 AM
Talking about Li-Poly, I reckon the little battery in the Nokia 8210/8310 would fit in a bit bus, and you could you charge it in the phone. Would make for a mean bus. But you'd rue the day you forgot to take it out and let it get discharged...
Old 01-14-2003, 10:10 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
also there are cordless phone batteries that are two 1.2v cells shrinkwrapped. most are 3.6 and too big to fit in a bit. ive seen smaller 2cell ones that would probably fit under the body with a little work.
Old 01-14-2003, 03:18 PM
BabyKiller's Avatar
whats the largest single battery that can use the seprate charger with 4 AA's that wont mess my car up
also im making a new thread since just batterys dosnt atract any1 who knows what the best gear is ect.
Old 01-14-2003, 03:21 PM
hogjowlz's Avatar
you can probably use any of them just dont let them overcharge.
Old 01-14-2003, 05:07 PM
BabyKiller's Avatar
Unhappy
but what would fit?
Old 01-14-2003, 05:10 PM
hogjowlz's Avatar
do a search on battery basics 101
Old 01-14-2003, 05:48 PM
BabyKiller's Avatar
read it already
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 07:51 PM
Battery Runtime Tests Namuna Bit Char-G / MicroSizers 25 09-20-2003 10:35 AM
Temp 7.2 battery mod DRRfanatic425 Dynamite Rocket Racer Parts and Hop-Ups 1 08-09-2003 10:47 PM
Battery Basics 101 Namuna Bit Char-G / MicroSizers 35 06-29-2003 09:17 PM
CRAP - battery problems! syncronized Bit Char-G / MicroSizers 4 04-15-2003 08:34 PM
