Old 01-13-2003, 11:18 PM
RDOG1 RDOG1 is offline
Exclamation Trouble w/ bit steering...
Even with a full charge my bit seems to not want to steer. It steers good one way, but has trouble in the other direction. I've tried adjusted the little white slider on the bottom, but it didn't help. Any suggestions?
Thx
Nitro makes my nose tingle!
Old 01-13-2003, 11:30 PM
Got it figured out guys. Pay attention. If you get even a tiny bit of metal shavings stuck to the bottom where the magnet is it will throw your steering off. As soon as I cleaned it it steered like a dream again.
later
Old 01-14-2003, 12:25 AM
mcharles13 mcharles13 is offline
Send a message via ICQ to mcharles13
i've found that my bit is very good at finding old staples.
*currently dead...waiting to be resurrected*
Old 01-14-2003, 10:30 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
i epoxied an extra steering magnet to the tip of my controller antenna just for that reason. its so much easier to suck metal off the car with another magnet than to try and pick it all off.
Old 01-14-2003, 04:01 PM
That's a good idea!
Old 01-14-2003, 07:11 PM
arceeguy
I had the exact same problem after mine got knocked off a table a few times. The problem was that the steering magnet had shifted off center in the carrier. You need to take the front end apart to check the magnet. I used a tiny dab of superglue to keep it in its spot.
Bit Steering 101 Namuna Bit Char-G / MicroSizers 59 11-25-2003 02:12 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Bit Propo Steering idea Dracos Bit Char-G Mods and Projects 0 11-07-2002 12:40 AM
