01-11-2003, 10:47 PM
precious painting???
hey guys i was just wondering if anyone knew what to do to paint the precious bodies but first i need to know how to remove the paint. i guess using nail polish remover is out of the question huh i hear alot of people say not to use it so what should i use?
secondly how would i go about painting it would i be painting from the outside cause the body seems a bit thick?
if i was to do decal stuff how would i do that just wait for the paint to dry mask it and cut out what i want with an exacto knife
glossy appearance what should i use to get a nice and glossy look?
sorry about all the questions and them be so unorganized i just kinda tought of things as i went along.
01-11-2003, 10:48 PM
Bad Driver
The other "How do i get the paint off?" thread said to use pine-sol. haven't done it myself.
01-11-2003, 10:52 PM
o i just remembered something from painting lexon bodys i used to steel wool the car to get the paint to stick better would that be good to do or would it scrap up the body?
01-12-2003, 12:32 AM
Told ya.
1.Remove the paint, any method.
2.DO NOT USE STEEL WOOL!!!
3. Mask off windows and lights and anything else you want.
Here's where it gets tricky.
4.Paint it.  you do not have to paint these from underneath just take it easy on the paint. Afterwards you can dip the car in future floor cleaner or spray it with a clear acryilic spray to get that high shine.
One tip I can give you if you wanna do splashes or flames is to paint the whole car that color first. Let dry over night. Then mask off the flames or splashes or stripes or what ever. Now paint the car the main color. Let paint dry fully before you remove any of the maskings.
I hope this helped.
____________________
Meh.
01-12-2003, 12:34 AM
how would i remove the paint and what paints should i use?
01-12-2003, 12:42 AM
Told ya.
I remove the paint by letting it sit in thinner for a few hours and then taking a toothbrush to it. The other method is the pine sol method (which I haven't tried yet) 1 warning on the thinner, do not wash the car with water afterwards, wipe it off best you can and let it dry, the water tends to cloud the plastic.
You can use any paint from enamels to acrylics. I use a spray can (I got my skills with the can from bombing walls as a teen) while some are more comfortable with bristol brushes and air brushes.
Experiment.
Meh.
01-12-2003, 12:44 AM
does rubbing alcahol work well? sorry i don't know how to spell it i don't touch that stuff.... well except for on new years
01-12-2003, 04:09 AM
Mr. Goop
Steel wool... steel wool works on larger lexan bodys because youpaint the bottom of the body, so you can essentially use a flat paint. the top of the body is still the glossy plastic/lexan. so only use steel wool if your painting on the bottom of the body.
i used rubbing alcohol to take the paint off mine... and an old toothbrush. due to the thickness of these bodys i would not recommend painting the underside of them. paint the outsied/top and then when your done, spray a few coats of clear on it to give it a good shine.
01-12-2003, 07:51 AM
Did you NOT read the posts above this one?
01-12-2003, 05:35 PM
should taking off the paint be really hard? i was using rubbing alcohol and was scrubbing at the paint for like 10 mins and nothing happened what's up with this so i need to scrub harder and longer?
01-12-2003, 06:03 PM
ok there has got to be an easyier way of getting the paint off this i just spent 30mins scrubbing hard at this bodie and all i can get off is the hood part is there something else i could except rubbing alcohol?
01-12-2003, 08:34 PM
Mr. Goop
i let mine soak in the rubbing alch. for about a half hour first. the hardest was to get the paint outa the fine lines/door jams etc...
01-12-2003, 08:36 PM
what did u do with the rest of the rubbing alcohol just dump it back in the bottle cause i don't want to waste it cause it's not mine
01-12-2003, 08:46 PM
Mr. Goop
i dumped it out. it was blue after i cleand the car... a bottle of the stuff only costs a buck.
01-12-2003, 08:47 PM
o hehe i didn't know that
