Old 01-08-2003, 05:54 PM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
hot wheels. can you use the wheels??
is it possible to use the wheels from a hot wheels car on the bit? has anyone tried this? i have noticed that there are some pretty cool looking rims/wheels that you can get on hotwheels cars.
Old 01-09-2003, 12:12 AM
Riven Riven is offline
<-Buying Electromag Coils
u could use any wheels as long as they wasnt to big around they are just glued on
Old 01-09-2003, 04:27 AM
Spanky's Avatar
Mr. Goop
just glued on. ok. i didnt want to destroy my car trying to remove the stock wheels. by looking at the front wheel i am assuming that that pin can be pulled out of the steering/suspension piece that it is attached to..
Old 01-09-2003, 01:52 PM
yeah the front has a pin the back is just glued just dont take off the gear on the back and it will be easy..u might have to make some spacers to space the wheels right on the axle but that shouldnt be hard either
Old 01-09-2003, 11:50 PM
cowfish_29's Avatar
yellow fish forever!
well, they are plastic....no grip, but that shouldnt be too hard.
Old 01-10-2003, 12:42 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
well ive tried using em...got lazy...stopped
but u have to do ALOT of sanding to make the width smaller..or else u going to ride lowriderstyle with tires sticking out a foot from the fender...
also...i suggest u use the smallest diameter ones...the wheels come in all shapes and sizes...
Hot Wheels Tunerz Bit Lord_HelmetR34 Bit Char-G Gallery 31 04-05-2004 01:02 PM
Hot Wheels K.I.T. Namuna Bit Char-G Parts and Hop-Ups 46 12-21-2002 07:15 AM
Hot Wheels KIT not quite compatible with Z-cars. LCKKN]HT Bit Char-G / MicroSizers 0 11-10-2002 05:21 PM
hot wheels body maker go_zz_go Bit Char-G / MicroSizers 2 10-13-2002 10:53 AM
Hot Wheels Bit sets!? Tech_Lord Bit Char-G / MicroSizers 23 08-23-2002 02:05 AM
