Old 01-09-2003, 06:30 PM
Loonie2ne Loonie2ne is offline
inconsistent motor
I have microsizer s2000 and when the motor runs it seems to speed up and slow down every couple of seconds, even on a full, fresh battery charge. I've gone through and cleaned it several times, didn't help. I've also tried letting the motor run for a while with the wheels off the ground like some other people said to do to warm up the motor and clear out junk that might be in there. That didn't fix the problem either. Can anyone give me some advice? do i need a new motor? Or could it be the battery, or maybe the cars main board it's self?
Thanks
Old 01-09-2003, 09:02 PM
MicroManiac1 MicroManiac1 is offline
I dont know what the answer to ur problem is, but im having a similar problem. BOTH of my 2.6 motors oly run at like 1000 rpms,, i have switched them around and put in the 2.2s but they still olny go REALY slow. Then i got an R-Spec (motors pretty cool) and it works fine, but i want to use my 2.6 which (when its working) has more lower end. HELP!!!!!!
Some people say im crazy ,everbody else....
says so too.
visit my site: www.avidgamers.com/microspeedsters
Old 01-09-2003, 09:14 PM
DakarV's Avatar
DakarV DakarV is offline
I'll think of something..
I got the same problem with my 2.2 in one of my bit char-g. Slows up, then speeds up.
Old 01-09-2003, 09:35 PM
spikeymike218 spikeymike218 is offline
TinyRC Sith Lord
what brand 2.6 are you guys using? the microsnap 2.6, bit char-g 2.6 or kit racer 2.6?
i know technically they're all the same, but this is what i found out:
my kit racer 2.6 motor was actually faster than the bit char-g 2.6.
when i had the bit char-g 2.6, it was slow compared the bit char-g 2.2. the 2.2 kicked its ass majorly. but after getting a 2.6 from the kit racers, and testing it against the bit char-g 2.6, the kit racer motor was noticably faster.
for about $2-6 depending on location of target, you can pick up a kit racer with a 2.6 and give that a shot.
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
Old 01-10-2003, 02:41 AM
shocon2k
The 2.2 that came in my Skyline MS was bad to start with. It just ran like shizz, but I never knew anybetter. When I got my 2.6 I was like WHOA.
Anyway, Microsnap is the motor that comes with KIT racers, which are the motors that come in Microsizers and Bits.
So technically they ARE the same....yeah, they're the SAME MOTOR. Same manufacturer. Other manufacturers are Bitmod and Darkside (dark something, I think its darkside).
Old 01-10-2003, 10:41 AM
MST3KPIMP MST3KPIMP is offline
I dunno if this would apply to your situation but my car was starting to slow down and when I looked it over I could see there was alot of lint in between the motor and axle. After removing it full speed was restored.
Old 01-10-2003, 04:02 PM
dieselboy dieselboy is offline
Send a message via AIM to dieselboy
My 2.2 from my microsizer was **** to start with. From the day i opened the package it ran VERY slow and with no torque to climb anything.
The funny thing is i did email microsizer and asked if there was anything i could do about it. The response i got "Every motor is actually the same!" <-- Ya well thanks for that little bit of information courtesy of customer service. It just made me mad becuase she was basically implying all microsizer motors are 100% the same and they never get product defects........ya right
I'm not sure if there is anything you can do though, as in most clones too, you get good motors and you get bad ones.
Old 01-11-2003, 04:19 PM
Well i contacted Microsizers earlier about a steering issue and they are sending me a new chassis. so hopefully the 2.2 motor on the new car will be a good one, if not i'll just buy a motor upgrade.
P.S. has anyone tried the motor leveling screw idea...?
Real Motor Analysis backtrack9 XMODS Mods and Projects 8 02-05-2004 09:13 PM
Xmods Video MicroRCEngineering XMODS 10 01-24-2004 11:39 AM
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 06:00 PM
(LONG)Another Motor To try "Nurelco Mustache Trimmer" Cyfiawnder XMODS Parts and Hop-Ups 25 12-19-2003 02:01 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 09:38 PM
