12-28-2002, 05:30 AM
Im a cat, miow.
Best Lightest LED MOD!
This is how I did my LED foglights for my Honda S2000!
I purchased some blue SMD LEDS (surface mount, these are tiny, weight next to nothing and are used in mobile phones mainly).
1. I cut the foglight holes out from my shell, placed the SMD LEDS in the holes
2.Held them in place with blue-tak
3.Soldered the enamelled wire to the SMD LEDS, and wired them in parallel to a small 3V Lithium cell.
ENAMELLED WIRE MUST HAVE THE ENAMEL TAKEN OFF THE ENDS BEFORE IT WILL MAKE A GOOD JOINT, OTHERWISE U MAY FIND 1 LED IS SLIGHTLTY DULLER THAN THE OTHER!
THERE U GO, LIGHTWEIGHT LED FOGS!
THE HEAVIEST THING IS THE SMALL LITHIUM CELL, BUT U CAN WIRE IT TO THE CAR BATTERY INSTEAD IF U WANT.
So what do u lot think?
Post it!
12-28-2002, 05:33 AM
Im a cat, miow.
I THINK I MIGHT GIVE IT ICE WHITE HEADLAMPS TOO, POSSIBLY UNDERBODY NEONS!!!!
OR MAYB SUM1 COULD MAKE BODY VENTS, CUT HOLES FOR THEM, THEN HAVE THE LIGHT COMING THROUGH!
Post it!
12-28-2002, 07:55 AM
will they work off the car battery!! if they do u might even be able to join it at f and b to make it come on and off when u go back and farward
12-28-2002, 04:25 PM
Im a cat, miow.
The Forward and Backward connection would stop the battery from being discharged as well! n no extra battery weight!
It'd wouldn't affect the car weight wise then!
As long as the leds dont sap up the motor power then - greaat!
Post it!
12-29-2002, 03:53 AM
how exactly did u cut out the fog lights?
i just cut mine out as well, but its a total mess... thje whole front of the body is scratched up.. and im bleeding!
12-29-2002, 10:56 AM
A good plastic / acrylic drill bit is the best way to bore holes in the body IMO. It also helps if you have something to hold the car in place while your doing it to keep it steady!
12-29-2002, 03:33 PM
Im a cat, miow.
I actually used a stanley knife, as iI have a steady hand, BUT!!!!! Do what clockw0rk said, its the best way!
Post it!
01-06-2003, 10:01 AM
Im a cat, miow.
Heres the wiring pic
Post it!
01-06-2003, 10:04 AM
Im a cat, miow.
front
Post it!
01-07-2003, 02:40 PM
MSN:eric_exec@hotmail.com
sick sick sick...
