Closed Thread
Old 01-05-2003, 10:54 AM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
Rotary
I will pay $30 and up for a mini rotary for a zip zap. I would also like to have a fuel tank and it has to make the car run at at least the equivalant of a 1.0 motor. I would like it to be faster though. I would like it fairly soon. It would also need to be fairly reliable. It would be best if it would be prefitted in the car. It would need a supply of fuel and I would need to know what fuel would be used. I will not be able to pay instantly. I would like the builder to build more than one. I would go up to maybe $75 per car but would like to keep it low cost. Hope someone can do it. You could also sell them as production but I would want a few engines to fit them in my bit-charg. I would also want them to have different performance qualities like high torque or high speed. I have attached a link to explain how a rotary engine works. Good luck!!!!!!!
http://www.howstuffworks.com/rotary-engine.htm
Old 01-05-2003, 11:17 AM
mattgoldey's Avatar
mattgoldey mattgoldey is offline
Just say 'no' to drugs.
Bit Char-G Toyota Celica (silver)
* Custom Mica Blue paint job (just like my real car)
* Rare Earth Magnet steering (Radio Shack Cat. No. 64-1895)
/]My 2000 Toyota Celica GT-S[/url]
Old 01-05-2003, 11:20 AM
jei$'s Avatar
jei$ jei$ is offline
WhaT
only 30 bux??
i can do it for a higher price
A man who desired nothing is invincible.
  #4
Old 01-05-2003, 02:02 PM
ShadowMage's Avatar
ShadowMage ShadowMage is offline
Box Racer
Send a message via ICQ to ShadowMage Send a message via AIM to ShadowMage
.....................um............ok............. ..please tell me this is a joke.
  #5
Old 01-05-2003, 02:13 PM
Odin_Knight's Avatar
Odin_Knight Odin_Knight is offline
Send a message via ICQ to Odin_Knight
just a question: with such a small fuel tank you're expecting to run how much time???? 3 sec? and by the way if someone can put a transmission with 6 gears and an exaust with a catalyzer (ambient friendly), and ,since we're asking, put also a radiator just to cool down the engine...
  #6
Old 01-05-2003, 02:28 PM
Silent_NightR34's Avatar
Got Mini-z?
how will this thing work? a bit is about the size of 2-3 pennnies and the engine itself is 1(not including the gas tank, battery,ect)...but i want 1..might make me go fast
ths would look so cool tho...every part for the engine would really make a diffrence in how it performs!!like real muflers...intercooler some how if u put turbo somehow..omg!!it would be soooo cooooool
  #7
Old 01-05-2003, 02:30 PM
investigating a little bit in that site you gave i've found this:
Mini-Rotary Engine
if you can see the engine itself has the size of a bit...
  #8
Old 01-05-2003, 04:24 PM
Racer9's Avatar
Tiny RC Pro
jei$ start now but it will have to fit all requirements. I might not need the car. Just include all required systems. I will build a turbo if you will build to all the specs. Try to make it so you can mod it. My brother would like one too. (just a thought, you could sell the engines and you or I could sell mods for them) I hope you can do this!!!!!!!
  #9
Old 01-05-2003, 04:26 PM
Racer9's Avatar
Tiny RC Pro
Just remembered. I said I would go to $75 if it includes car and meets and exceeds all specs. I would like it to fit in a Bit-Charg
  #10
Old 01-05-2003, 04:45 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Why don't you try a cox tee-dee airplane engine? just stick it and it's fuel on your bit's roof, and you have a viable dragster/airplane!
  #11
Old 01-05-2003, 05:07 PM
Racer9's Avatar
Tiny RC Pro
I want it to fit without wrecking the body. I also want gas tank fitted in front of the battery. I want it to work like this. You could just use a throttle and keep glow plug at constant temp. You might possibly do this. When you press forward it puts electricity into the glow plug and causes gas to heat up more for higher revs. I don't want to have to do a lot work on it because it is so small. jei$ try it soon. I want it to run on glow fuel.
  #12
Old 01-05-2003, 05:12 PM
Got Mini-z?
i jus got a great thought!!!sicince its a cumbustible engine u can put nitrous oxide in it some how!!!
  #13
Old 01-05-2003, 05:18 PM
Racer9's Avatar
Tiny RC Pro
That was an idea my brother had but the container would most likely explode and it is so small it won't last long. It is a cool idea though.
  #14
Old 01-05-2003, 05:46 PM
Racer9's Avatar
Tiny RC Pro
If you build it send a record to guiness world records for the smallest rotary engine in the world.
  #15
Old 01-05-2003, 05:50 PM
Got Mini-z?
lmao!or the first cumbustibel engine inside biit
Closed Thread
ive created a bit scale rotary hogjowlz Bit Char-G / MicroSizers 5 05-21-2004 11:44 AM
what do you drive fightingmonkey Bit Char-G / MicroSizers 11 03-02-2004 02:31 PM
Mock Rotary engine under clear hood. Kingofjapan Bit Char-G / MicroSizers 39 09-05-2003 09:34 AM
