Old 11-23-2002, 02:59 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
stupid zipzaps are just useless!
lol jk but I jus like ma bit
Old 11-24-2002, 12:30 AM
dhdsf dhdsf is offline
They must have put them in there for a reason in the first place. Maybe over specced though so as a backup??
Dave
- Skyline GTR set
- 2.6 motor
- Blue gears
- Medium soft all round
- Cat 5 aerial mod.
- Crip cap removed in controller
Old 12-01-2002, 05:58 PM
nissan2S nissan2S is offline
how do you install it
do you just pull it out and stick the new ones in
Old 12-01-2002, 07:18 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
You have to use solder. I take a heavy piece of wire, wrap it around the iron tip and make a much smaller effective iron and tip.
I am looking for surface mount LEDs also, if anybody has any sources.
BAE
Smaller models, more control
Old 12-01-2002, 07:30 PM
DarthRacer's Avatar
DarthRacer DarthRacer is offline
Sith Bit Racer
Send a message via AIM to DarthRacer
Originally posted by Dayfall
I got my resistors from an old hard drive.
Holy Cow! Good idea. I have so many old HDs it is not funny.
I know my resistor color codes BBROYGBVGWGS,
but can someone help me identify SMD resistor values?
Thanks
- Calsonic
Old 12-17-2002, 12:59 AM
Cutlsp Cutlsp is offline
Send a message via Yahoo to Cutlsp
you can go here to get surface mount leds http://www.toyeast.com/
i bought some i'm just waiting for them to get here and do you know some one that can help me with my bad 3.8 motor it died this weekend it will still go but the car needs a push to get moving i don't know whats wrong with it reply if you know anyone that can help
Old 12-18-2002, 08:14 PM
Thanks for the tip on SMD LEDS. I think that they are a better idea.
For DarthRacer, No 3.8 motor can be high speed and torky at the same time without being designed for running times about 30 seconds or less. NiMH would be absolutely mandatory. You may fix your problem by seating the motor, Chap Sticking the gears, and polish and graphite lube the rear axel. I hope that this helps. Also a DansAm body is smarter for the 3.8 due to their lightness. BAE
Old 12-19-2002, 12:22 AM
how would i seat the motor? and what is a dansam body and where would i get one? if you know where i can get one let me know okay thanks for the helpful advice.
Old 12-19-2002, 11:22 AM
zzz zzz is offline
will this work on a dual 150mAH mod car?
Old 12-19-2002, 02:41 PM
You carefully align the motor by inserting tiny shims. Toilet paper is good for very small changes. Paper for thicker.
Tiny sells DansAm bodies. BAE
Old 01-01-2003, 05:09 PM
arceeguy
.......and I would have left it that way but I replaced the transistors with mosfets.....
FETs! What was the part number of the FETs you used? I was thinking of doing the same thing, but FETs require a higher "turn-on" voltage than bipolar transistors. And since the supply is only a single cell, I canned that idea. The Zips can sure use a better H-bridge circuit!
Old 01-05-2003, 01:08 PM
Fury Fury is offline
Anyone know if this can also be done for Bits?
Old 01-24-2003, 08:23 PM
dohc's Avatar
dohc dohc is offline
TinyRC Hacker
fury, if you have a bit, do my 3 cell mod. you'll smoke the zip like that. fet upgrade comming soon. i will now hack into the pcb board and give you the results
Old 01-25-2003, 10:01 PM
Since you are soldering anyway.
How about a Bit circuit board. Give it both the FET and 3 cell mod. Put it in a Zip shell so the 3 batteries are all inside. BAE
Old 01-26-2003, 06:10 PM
Project RC's Avatar
Project RC Project RC is offline
RC TUNER
Can you just use a RadioShack 100ohms resistor?
RMYC's extra torque mod rmyc Bit Char-G Mods and Projects 10 07-26-2003 12:04 AM
torque mod help CRUMB ZipZaps 0 02-27-2003 08:44 PM
max torque mod for bits? dieselboy Bit Char-G / MicroSizers 0 01-27-2003 08:33 PM
