10-29-2002, 01:09 AM
deviant bit char-g pro
Hummer conversion kit?
When will this be available? What items aside from a hummer body will this include. I saw a blurb about it on your site and it tweaked my interest. I am looking forward to the kits availability.
10-29-2002, 01:59 AM
Moderator - Modifier
Its in stock, but we cant seem to find the time to code the store pages. The Hummer (military grade) kit is just a body, with removeable roof mount turret gun, olive green PCB cover, 4x4 style tires (front and rear axles). The PCB is required to fit, as it is slightly recessed. If you want to use the clear PCB, then you have to pop off the windsheild on the Hummer, because the antenna coming out of the clear PCB will get crimped.
FYI: Sharper image now carries the new H2 hummer bodies (we dont).
11-21-2002, 07:04 PM
TinyRC Fox
how much and can you post pics?
01-02-2003, 10:20 PM
Ultimate ZZ racer!!!!!!!!
When will you stock it cause I want to buy it.
01-05-2003, 01:38 AM
Hello QFM? When are you going to stock it!
01-05-2003, 12:29 PM
TinyRC Fox
i thnk they are ebay actions. email qfm for more info.
01-06-2003, 05:37 PM
Hi guys,
Thanks for the interest. When the products actually arrived, we were disappointed with thier compatability. In addition to the body snapping on loosely, the axles were of a different size, and the antenna would get pinched w/o minor modification of the front windshield. The tires also needed modding before transferring to a Bit, and we had hoped it would just snap on. The reason the tires did not swap properly, is that the rims were a diff diameter.
SO..... we liquidated them on eBay. Unless you can get the Hummer clones for a great price, dont bother buying them for conversion Kits for your Bit. They dont swap well. This is in regards to the H1 hummers only. I have not had a chance to test the H2 Hummers yet. They look more promising and more attractive as well.
Hope this helps. Sorry guys.
QFM-R
