Old 10-22-2002, 06:14 AM
DeeChan DeeChan is offline
double cell or single cell
when people do the double cell mod, isn't it just combining 2 1.2 v batteries? why not use 1 2.4 volt battery? would it work or would the cell size be too big?
I have the whole booster set for a ZZ but it doesn't have the stabalizers for sale. Email me for more info.
Antenna from RS-4$
Ripping off some useless controller plastic- negative 2$
getting 15'+ of range-priceless
Old 10-22-2002, 08:11 AM
Namuna's Avatar
Namuna Namuna is offline
Re: double cell or single cell
- Yes
- Because there are no such things as 1/3AAA size, 2.4v batteries
- You're probably thinking of the bigger size batteries and yes, they'd be too big to fit inside the PCB.
Old 01-03-2003, 06:44 PM
Kaizer-Stryke Kaizer-Stryke is offline
Send a message via AIM to Kaizer-Stryke Send a message via Yahoo to Kaizer-Stryke
theres gotta be a nother way to get the same effect of the dual cell mod without using 2 cells theres just gotta!! until someone comes up with a way ill keep messing up batteries trying to do the mod.
Old 01-04-2003, 08:54 AM
epilot epilot is offline
Lets not confuse terms. A battery can be any number of cells. Therefore there is such a thing as a 2.4 volt battery but it would still consist of 2 cells. Rechargable cells whether they be NiMH or NiCd are nominally 1.2 volts pr. cell. Any increase in voltage would require more cells.
Moving onto different chemistries, we have the non-rechargeable Lithium cells (like the CR2 used in cameras) that have a nominal voltage of 3 volts.
Last we have Lithium Ion or Lithium Polymer cells with a nominal voltage of 3.7 volts pr. cells. These can be recharged and have a very high energy density. There are 145mah Li-Poly cells available the will fit on top of the PCB in many Bits - depends a bit on the body shell. The downside is that you need special chargers to charge Li-Poly cells and they must not be drained below 3 volts as this will ruin them. I use these cells a lot in my indoor R/C planes - all in the sub-ounce category.
Conclusion: If you want more power there is no way around adding cells. We can just hope that smaller cells with large capacity show up so can more easily fit extra cells.
A word of warning: More than 4 cells (max 5 volts) can damage the receiver!
Hope this helps
Michael
Old 01-04-2003, 11:28 AM
wow thats alot to take in, but its nice that u mentioned a limit i always wondered if there was one.
Old 01-04-2003, 11:46 AM
bitbeater bitbeater is offline
Try using some 'flux' when soldering the batteries. It will help alot.
Old 01-04-2003, 12:10 PM
Some cars have alot more room then others.These are 250mah 1/3 AA cells..
Old 01-04-2003, 12:11 PM
Old 01-04-2003, 12:12 PM
Old 01-04-2003, 05:36 PM
whats flux?
Don't Knock It Till You Try It. Don't be a hater.
Old 01-04-2003, 06:38 PM
Its like grease that will make the solder stick alot faster.
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 04:27 AM
Single cell wheelie poppers... ph2t Bit Char-G / MicroSizers 21 06-22-2003 07:20 PM
Mosfet Power for single Cell Bitīs!!!! Grasziege Bit Char-G Mods and Projects 26 06-04-2003 10:35 AM
Mosfet Power for single Cell Bitīs!!!! Grasziege Bit Char-G / MicroSizers 10 02-06-2003 09:34 PM
