Old 01-03-2003, 02:20 PM
Ganpachi Ganpachi is offline
210 mAh NiMH batteries
I found a site selling 210 mAh NiMH batteries.
Want to see if these will work ok with Bit Chars.
I've added the website below. It'll bring you directly to the 1/3AAA spec sheet.
http://www.batterieswholesale.com/pr...-aaa-210-h.htm
Old 01-03-2003, 03:55 PM
Namuna's Avatar
Namuna Namuna is offline
I read the size specs for that as:
Diameter: 10mm (no problem)
Height: 20.5mm (BIG problem, won't fit)
The size rating of '1/3AAA' is non-standardized, which stinks when finding high capacity batteries.
To safely fit into a Bit, a maximum of 16mm height must be used.
Old 01-04-2003, 01:52 PM
Ok..I looked at the specs for the 1/4 AAA and it's 14mm and it gives 150mAh so i'll test em out. so max dimensions would be 10mm x 16mm?
Old 01-04-2003, 05:47 PM
Krabill Krabill is offline
Um . . . you really don't need a bigger battery to get better run times.
If you take your stock battery out and place it into a peak charger, you'll get over 20 minutes of run time.
The problem is that the bit chargers don't fully charge the stock batteries. I haven't done any time tests, but I usually charge mine 2-3 times and I get very long run times that way. I think I read somewhere that 5-6 was a full charge, but I don't want to over charge the poor little thing and 2-3 consecutive charges give me 10-15 minute run times, which is plenty.
Old 01-05-2003, 05:32 AM
dang..wish you posted this earlier!
I already ordered some new batteries..
ah well..no biggy..$13USD isn't much anyway. once i change to the 3.8 motor in my Wild Char, having the extra juice in the nimh battery will probably help. also been thinking of going 2.4V on it too so need another battery anyway..
Thanks for the info though..i'll try charging my bus on my stand alone for 4minutes and see how long I get out of it . Maybe i'll leave thatone stock if it runs long with a 2.6 in it.
Old 01-05-2003, 10:06 PM
carman carman is offline
hey
hey when u charge the battery in the peak charger. how long do you keep the batter charged into the charger.
Old 01-06-2003, 08:06 AM
Chilledout Chilledout is offline
mate the peak charger does what it says on the tin, basicaly it monitors the voltage that the battery has whilst it charges as soon as it sees the voltage geting lower it knows it fully charged.
therfore the time the charger will charge thye battery for will change depending on numerouse factors including residual charge in the battery.
Old 01-06-2003, 01:42 PM
I've got a GP charger for my regular nimh batteries. Charges my 1800mAh NiMH batteries. How do I tell if it's a peak charger or not though?
forgot to ask that last post.
Old 01-20-2003, 07:28 PM
BabyKiller's Avatar
lol i some energizer2's(new) in my controller charged the car 8times in a row got 50min+play time with great speed and handeling WITH THE STOCK BATTERY
+ (4.8v)
Batteries: mAh ratings drewdown84 XMODS Parts and Hop-Ups 7 01-02-2007 02:36 AM
LXX Controller with NiMH batteries neon Bit Char-G / MicroSizers 1 12-24-2004 07:34 AM
Nimh vs Nicd Vote Xmodracer1 XMODS Parts and Hop-Ups 13 07-06-2004 07:32 PM
Nimh batteries ? RabieS For Sale/Trade 10 03-30-2003 09:44 PM
