Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 12-12-2002, 04:29 PM
2000-redrider 2000-redrider is offline
what motors have you tried?
I just wanted to know what motors you guys have tried and what you thought of them. Has anyone tried using 1/24 scale slot car motors? Will slot car motors even work?
Old 12-12-2002, 06:42 PM
irc irc is offline
A slot motor could work but if it's to modified it could burn up the Esc. The 180 motors work well and they are safe to use. The fasted one I have tried is a GPM 180 Hi speed black motor.
" THINK FAST "
Old 12-12-2002, 07:24 PM
What would cause the ESC to burn out, a large motor, or a high (higher than 7.2) voltage battery pack, or both? Sorry for the newbie questions, but this is my first electric rc car.
Old 12-12-2002, 10:03 PM
Siress Siress is offline
Send a message via AIM to Siress
it would heat up and transmit the heat through the wires back to the ESC causeing it to fry
Old 12-12-2002, 10:52 PM
irc irc is offline
A modified motor pulls to much current through the esc so it will burn up unless it is built to handel it. To much voltage from the battery could do the same. The DRR will take 7.2 volts and a 180 motor with no problems.
" THINK FAST "
Old 12-28-2002, 12:24 AM
Why was the motor even near the drill bit? If your doing something like that you MARK the spot then drill it.
Old 12-29-2002, 12:21 AM
I must look at a pan car motor! I don't recall the holes being that small! THATS TINY, if they are smaller than the mRS4 motor mounts that is.
Old 01-03-2003, 01:51 AM
dtmracer dtmracer is offline
slot car motors are probably the best motor for these cars now that i think about it. that parma motor you are talking about is i think called the 16d correct? well that motor comes in the brp 1/18 car. i it is basically a pan car. it has speeds of 20mph stock in that heavy 1/18 pancar, so if it were in a 1/24 it would be great. they are great because they have lathes for them to true the com and brushes are changeable and cheap. they even sell a version that has adjustable timing. yes you would need a pretty good esc to handle these though. another thing, they are meant to run on 12 volts on the slot car track, so no worry of burning it up with extra cells.
Old 01-03-2003, 01:55 AM
irc irc is offline
good thinking DTMRACER my BRP fly's with that motor. It would rip in a 1/24er. Hum..... I might have to give it a try this weekend.
" THINK FAST "
Old 01-03-2003, 03:42 AM
BobbyDigital BobbyDigital is offline
Hmm.. My bro has just a ton of slot car motors brand new bodies etc.! He has some decent slot car mod motors from what I remember .. I might have to get him to let me into that tackle box he has collecting dust under his 10th scale nitro\electric wonder land of a workbench..lol.. Please let everyone know how that works out for you irc.. These small cars seem really versitile when it comes to motors!
I wonder if the 1/24 scale slot car bodies will fit the DRR?
Cheers all..
Speed kills__Drive a Honda!
Old 01-03-2003, 03:46 AM
The slot car bodies do not work. They are to small. The electronics are to high of the DRR.
Old 01-06-2003, 03:02 AM
Although you don't have to worry about burning a 12v slot car motor up since we're only using 7.2v, wouldn't it also mean that the motor won't be running at 100%? If a motor is rated at 30,000 rpm @ 12v, would it only be running 18000 rpm @ 7.2v?
Old 01-06-2003, 12:28 PM
HAHAHAHA ~good~ GREAT point. that one got overlooked by some....I just saw the first slot car track I have ever seen and I was impressed. Those things FLY! but the lack of controle turns me away. although the drag strip thing is awsome
Old 01-06-2003, 06:38 PM
still with 7.2 volt pack, brp is super fast. with drr you could gear up alot because of the weight of it. also i thought slot car motors had more rpm than 30k. i know for sure that they have butt loads of torque. i have a old slot car motor and i hooked it up to my 4 cell and it seemed fast. also you can advance the timing on alot of them too. they are basically a 1/10 motor. the only aspect i am not sure of is how much juice they guzzle. you may need to size up the battery issue. you might need to run aa's. does anyone here own a brp? if so how much run time do you get with a "aa 7.2 volt pack"?
Old 01-19-2003, 12:45 AM
Hicountry Hicountry is offline
I just put an Orion core motor in mine. Plus a 7.2v pack. I can't believe I am about to say this........Maybe there is such a thing as too much power. I also have a 13t pinion. It helps, but not much. Now for the eternal search for TRACTION!!
Dynamite Rocket Racer,180core,7.2v,13t pinion
Epoch Spd Rcr/Rcr X, #9 NASCAR
1/24 NASCAR Homebuilt
1/10th NMT Dodge
Need Help building HO TTTT
motors and pinions? sawhit4 Bit Char-G / MicroSizers 0 06-04-2005 05:43 PM
Making motors faster. moebrown20 XMODS Mods and Projects 0 10-15-2004 03:01 PM
Xmods Video MicroRCEngineering XMODS 10 01-24-2004 11:39 AM
FS new BCG motors feishiaada For Sale/Trade 0 05-14-2003 02:26 PM
bit motors...ZZ motors....DKS motors tarnjit ZipZaps 1 12-06-2002 05:06 PM
