01-01-2003, 12:30 PM
Climbin' Hummer
I love my Hummers but found them to be a bit wimpy when it came to their terrain capabilities. I first tried to swap the motor with a longer pager motor. Same speed as before but more torque and hence better acceleration. This mod is very easy. Most of my cars get the bigger motor installed.
Still not completely satisfied I decided to go further. First I added an additional stage of gearing. Now we're talking! It will climb 30 degrees inclines with ease. More than that it tends to flip over backwards. Only problem now was the speed. It was too slow. Cure: Add another cell. After some case trimming I got two 70mah NiMH cells into the car. I had to move the large cap for the dc/dc onto the other side of the PCB to make it all fit within the body. Now it has great torque and good speed (app. like to original) I tried a 145mah Lithium Polymer cell (3.7 volts) and this made the car too fast IMHO.
The mod is a bit fiddly to do but well worth it. Next step is to make some new tires from dense foam rubber for better grip (and larger diameter to increase clearance)
Michael
01-02-2003, 01:38 PM
I'll think of something..
Like the hummer modifications. What holds down your pcb and motor? The last time I tried a mod, I fried my motor,  . Anyway, nice idea.
01-02-2003, 01:49 PM
Motor is held on with cyano glue (super glue), PCB with a piece of tape.
I think the pager motor I use is more robust than the original motor.
You should see this thing move with a Lithium Polymer cell - it pops a wheelie for the first two feet!
Michael
01-02-2003, 10:47 PM
It's a cool mod, keep us posted on the finished mod.
03-25-2003, 04:49 PM
Riiiiiight...
Re: Climbin' Hummer
epilot:
How did you gear it down so low? Or it that a function of the Hummer? What brand is the Hummer?
Thanks
Michael
1 Civic X-Mod AWD 1 RSX X-Mod
2 MicroSizers 3 Shens
5 Precious 1 ZipZap
2 LXX Boosters 1 H1 Hummer
2 Bit chassis in process of mod'ing
2 Auldey 1/32 2 Auldey 1/16
1 Team Losi XXX-NT
03-25-2003, 05:55 PM
whats imho?
03-25-2003, 06:13 PM
they say im slooooow eh?
got BITS:
In My Humble Opinion
epilot:
Guy, that is insane! Dual cell, and then geared down more!?!?!? Too cool. Does it have lots more power AND speed?
03-27-2003, 08:43 PM
Blitzer Sonic
Why did you put an idler gear as your pinion gear?
03-27-2003, 08:50 PM
It's not. The idler gear takes place of the OLD pinion gear, but the new one is above it, attatched to the motor.
03-27-2003, 09:17 PM
XMOD AUDI TT (my wish)
u did all that and u only get 30 degree climbing???
my stock precious gets 45 degrees (actually measured)
climbing on a full charg with ease
although i must say that isss a good idea, u probably get more than 30 degrees though
03-28-2003, 02:17 PM
Poor Student
45 degrees? i dont believe you.
Fight Crime <--> Shoot Back
