01-01-2003, 07:04 AM
Im a cat, miow.
Proportional Speed
I know some people have controlled their bits using real Radio Control transmitters, when u did, did u get proportional speed?
So what do u lot think?
Post it!
01-01-2003, 12:44 PM
Im a cat, miow.
I know sum1 here has tried it! All post ur ideas! i dont want 1 of those crap posts!
Post it!
01-01-2003, 01:54 PM
Retarded Stunt Driver
you would have to seriously mod the car.
01-01-2003, 05:03 PM
Im a cat, miow.
I was gonna modify my tomy controller,so it could pulse, but i thought that if i used a real transmitter,it would already pulse the signal,therefore creating variable speed!
Sum1 try the real transmitter idea!
All u have 2 do is open up ur char g controller, read the crystal frequency, then get 1 of these and put it in ur REAL transmitter.
Theres been a loada people viewing,but no 1 adding 2 my thoughts!
Post it!
01-01-2003, 10:14 PM
Your car's PCB is a radio controlled on-off switch. A proportional controller will send proportional signals, but your car would need an electronic speed controller (usually a $100 item) to control the proportional throttle. Also, to have proportional steering, you would need a steering servo with feedback.
01-02-2003, 09:25 AM
running a pulse circuit from the controller would be interesting.
01-02-2003, 12:32 PM
Yeah but how would you rig up the boost button on your remote? Or would you run it so the boost kicks in half a second in or something? That way you could tap in tight turns and open it up on the straightaway.
True proportional doesn't seem feabible, but these 2 speed ideas are cool.
01-03-2003, 03:27 AM
Im a cat, miow.
I think the way it would work would be to have the normal forward and backward at full spped (AS THEY ALREADY ARE)
and to have a pulsing circuit connected in parallel to forward switch,
this circuit would have a switch on it, and when u pressed it the car would run at 1/2 speed.
ALSO 1 thing I was wondering, Why does a boost car at full boost run faster than a normal bit with the same specs?
Is there a resistor or transistor that needs to be changed to achieve the same speed?
Post it!
