Old 01-01-2003, 09:19 AM
zombiebaby's Avatar
zombiebaby zombiebaby is offline
drag race king
dual battery
I cant keep a charge in my dual battery set up it will go for 30 secondsand thatsd it I have a charger made 2 batteries taped 2gether and a charger stand off an old controler . should I try three or am I just screwed
IF I WERE GOD YOU'D SELL YOUR SOUL
Old 01-01-2003, 09:35 AM
jerrylo
mine is doing the same thing, I am going to try charging with a 4aa setup as soon as RS opens up so I can get one. I am told that this is my problem.
Old 01-01-2003, 09:43 AM
zombiebaby's Avatar
drag race king
thank a lot
Old 01-01-2003, 01:33 PM
tory_103 tory_103 is offline
Sangru Lava U Sangru
Send a message via AIM to tory_103 Send a message via Yahoo to tory_103
you need to go to Radio Shack and get product #270-409 ........ its a 4AA Battery Holder and costs $1.94(tax included)........ looks like a black square box with 2 wires coming out of it, thats all it is........ you wire your charge station to it(takes 10 seconds TOPS!) ........ put 4 AA batteries in it, hook your car up, turn the switch on on the charger, wait 90 secs(this is how i long i do it for) and VIOLA you are done and ready to go!
i had the same exact problem as you did, and this fixed it...... so good luck !............. l8r
Old 01-01-2003, 02:17 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
would there be any way to use the double charge timer cap and the 4AAA stand alone charger so u get 90 seconds each time and it wont overcharge? maybe incorrperate the timer light as well. BTW even tho i did th emod to my controller my timer light still works on normal bits
timed dual battery re-charge? JTM Bit Char-G Mods and Projects 0 12-26-2002 05:45 AM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
