Old 12-28-2002, 03:49 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
help, i need a picture of controller curcuit wiring
oks hears the deal, i need a picture of the wiring of the controller, because i need to know where the antenna wire is wired to..
i added a telescopic anteana wire right in the middle of the controller, and just forgot to wire it back har har
i havent used my Bit in a month, because i couldnt figure out where the damn wire goes, so i just let it for a while, because i was messing with my 1/32
now, i sort of want to bring my bit around like i used to, so i really need a good picture of where the darn antenna wire goes to..
thanks
Old 12-28-2002, 10:14 AM
Dratheus's Avatar
Dratheus Dratheus is offline
Bâshbad the Wicked
MTL,
Took my tomy controller apart just to make sure. Check out QFM. They've got a controller diagram you can download. The antenna on the diagram is directly to the left of (switch 1). (SW1 on the diagram) On your PCB, the antenna connection is at the opposite end of the solder connection of L3. Good Luck
Stay out of the DAYLIGHT!!!
Old 12-28-2002, 10:34 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
hmm...funny that i never saw that ever since i saw qfm back then, har har
pretty useful, although kind of hard to read....but it says its the diagram for the 49mhz controller, im gonna guess this is the same for all controllers yah?
thanks alot
Old 12-28-2002, 10:43 PM
Dratheus's Avatar
Bâshbad the Wicked
Yup, it's the same......the only difference that I know of is the crystal.
Controller trouble... Sleeping911 ZipZaps 0 06-25-2004 12:33 AM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 05:12 PM
How do you hold your SE controller? rfnagel ZipZaps SE 6 10-06-2003 08:11 AM
NEW CONTROLLER MOD! Check it out.... mike_diaz19 Bit Char-G / MicroSizers 13 12-19-2002 12:02 AM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 06:19 PM
