Old 12-27-2002, 09:49 AM
SoulflyCRX's Avatar
SoulflyCRX SoulflyCRX is offline
My Z-car sort of "stutters" when it drives.
I just picked up a new z-car (bit clone) and most of the time when I drive it around the house, it is just fine. But sometimes it starts to "stutter". As in, it will keep keep turning on and off in rapid succession.
The z-cars have an LED In them, and when I am driving, it with keep flickin on and off. (It only turns on when the forward or revers buttons are pressed) and the car "stutters" and stops. If I get closer to it, or turn my controller slightly, it will start to move just fine again.
What is the most likely problem? Interference? I make sure all the parts within the car are secure. And help is much appreciated.
My freq is
- Ryan
Red "Toyota Celica" Z-Car
Old 12-27-2002, 12:30 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
try this. take a q-tip(the kind with the plastic shaft) and cut the ends off and run the antenna wire through it so it sticks straight up in the air. that helped my zipzap somewhat.
Old 12-27-2002, 01:06 PM
SoulflyCRX's Avatar
Well the antenna is pretty much bent up straight in the air. Its behaving very odd. I have another z-car and its the other freq. It does not do this at all
- Ryan
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 10:59 PM
Futaba 1/20 Delphi Indy car ksavage68 Other Tiny RCs 3 04-08-2003 08:16 PM
Help Krylon Killed my car ml22 Bit Char-G / MicroSizers 19 03-25-2003 05:27 PM
Red white and blue rally car ml22 Bit Char-G / MicroSizers 9 02-24-2003 02:58 PM
