Old 12-23-2002, 04:57 PM
Ovgron's Avatar
Ovgron Ovgron is offline
I own you
Question How do i lower the body?
How do i lower the body? (not chassis)
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
Old 12-25-2002, 01:25 PM
SubaruWrxSti SubaruWrxSti is offline
Send a message via AIM to SubaruWrxSti Send a message via Yahoo to SubaruWrxSti
Which body is the question!
Old 12-25-2002, 05:37 PM
DioXidE DioXidE is offline
Send a message via ICQ to DioXidE
a white R34 Skyline
Old 12-25-2002, 06:42 PM
Silent_NightR34's Avatar
Got Mini-z?
all 34 skylines have they ssame body right?cuz i wanna lower my custom skyline...
Old 12-25-2002, 06:47 PM
Shypo's Avatar
Shypo Shypo is offline
Regulator
i would jus shave new slots into the shell, or do Drive WRX's. i think its his sorry if i havent given credit but its putting a new tab underneath the existing one so it slots in at a lower level
go fast, be free, with low CC
Old 12-25-2002, 11:10 PM
Thanks for that,
I'm looking at the skyline shell atm and i can't find any more spaces to put new holes in there...
Old 12-26-2002, 04:00 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
just cut the mounting tabs off and mount new ones lower with some super glue.. should be strong enough to hold the light wieght of the car, and the pressure used to remove the body.. course this would be modifying the chassis and if you fuxor it up well... if you cut new slots into the body.. then fill the old holes in with some plastic hobby filler.. available @ most hobby shops comes in a tube like the model car glue.
i wish i could use the IMG tag in signatures....
Old 12-26-2002, 12:32 PM
Got Mini-z?
to post a pic u go put the file name of the pic in the attachment part...the format has to be gif, jpg, bmp, jpeg..or u can just check wat u can hae ursef...
Old 12-26-2002, 01:02 PM
Ok this is what I did to lower my body! I took a x-acto knife(remember only for the skyline body) and you see the plastic right above the tab there? Make a lil hole there so you can press your tab up! so now youll have a lowered body! But CAUTION! You need to shave out the front wheel wells and also leave enuf clearance so that the wheels can TURN! This is ALSO TO YOUR OWN RISK! But the good news is ive done it BE4!!!! It works Just be very carefull at how you do it!
Old 12-26-2002, 05:28 PM
evileric evileric is offline
MSN:eric_exec@hotmail.com
This is what I've done to my WRX. I'm working on a step-by step with pictures of how to cut and re-glue the tabs lower.
One tip I can give you: Be careful to superglue into the correct position the first time, otherwise you'll weaken the plastic everytime you re-glue it, and it will look like crap eventually.
Also, the pressure on the new tab may be more then it was before, so you might want to sahve a bit of plastic off the end when you cut it, to make sure that the tab doesn't break off. (Eric re-reads his post and scratches his head, wondering if it makes sense... Meh)
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 12:19 AM
how do i lower a body??? sharkman_081490 ZipZaps Mods and Projects 1 09-26-2004 05:42 PM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 01:48 PM
lower body idea.. has anyone thought of this? SupraFreak00 ZipZaps 7 07-06-2003 07:14 PM
is there any other way to lower ur car but not by tab lowering or dremal body cut.... eclipse98 ZipZaps 1 06-27-2003 08:35 PM
