Old 12-18-2002, 03:33 PM
rallger's Avatar
rallger rallger is offline
switcher
Send a message via AIM to rallger
help with rear axel
hey i borrowed my friends sipsap today.(waiting for mine to come in mail)anyways, the rear axel is loose and the pinion does not always touch it.does anyone know how to tighten it. any help would be great.thanx
Old 12-18-2002, 03:34 PM
rallger's Avatar
switcher
whoops
i should have written zip zap not sip sap.
sory
Old 12-20-2002, 08:47 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Take an exacto and slice the chassis just behind the hole that holds the axle in place. On the side that houses the battery. This makes a gap that closes the hole slightly when the plastic is cut and produces the gap. Fill this gap with epoxy. This mod works very well and is barely noticeable. What you are doing is making a sliver of plastic that bends inward closing the hole. Filling behind the sliver of plastic ensures it stays put.
Old 12-20-2002, 10:22 PM
I2ed I2ed is offline
Send a message via AIM to I2ed
pictures?
Blue Honda ZZ w/ Dual Batt Mod
Old 12-21-2002, 09:21 PM
Azimov's Avatar
I'll try. The problem is that the computer that I use for graphics has my scanner and Photoshop on it but the monitor died. I need to get it going again and will post pics then.
Old 12-21-2002, 11:09 PM
zipzap
good idea
I will try doing just that to my loose axel.
Thanks
Old 04-24-2003, 01:35 AM
micro_Amps's Avatar
micro_Amps micro_Amps is offline
or you can try a clip like this......
loose axel clip
uA
Rear Axel Trick grAPH XMODS 24 07-06-2006 12:00 AM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
whoa, Taiyo rear is removable, meaning: CUSTOM T BAR REAR SUPSENSION MOD TIME!!! MTL Auldey (All) 6 12-30-2002 07:53 PM
rear axel troubles lookatme ZipZaps 2 10-20-2002 09:59 PM
