Go Back   TinyRC.com > Other Tiny RCs > Plantraco Desktop Rover > Plantraco Desktop Rover
Old 11-20-2002, 03:42 PM
BillyBonz's Avatar
BillyBonz BillyBonz is offline
Improved Climbing
Here is an easy way to improve your Rover's ability to climb without flipping. The bar on the bottom of the track can be pulled off. There are 3 molded in plastic pins that keep it in place. CAREFULLY! pull this bar straight out and give it a try. I didn't have any increased problems with the treads coming off. The only thing is the pins kinda catch a bit on the treads when you start climbing an object. Time to start working on a suspension system like I saw with the Digi tanks.
Here is how it looks without the bar in place.
Old 11-21-2002, 12:12 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Cool! Have you tried adding weights to prevent backflipping when climbing?
Old 11-21-2002, 12:52 AM
BillyBonz's Avatar
Yes, the added weigh does help. I'm happier with those side rail removed and no weights. When I use both the underside of the tank bottoms out too easy. It doesn't flip, but it does not climb as good either.
Old 11-22-2002, 04:52 PM
Russ's Avatar
Russ Russ is offline
Send a message via AIM to Russ
Hey I just pulled those plates off & it works!! It didn't change anything about the angle it can climb, didn't expect it to, but there is this one book I have just never been able to get up on and now I can Never thought about pulling those things off!
Old 12-13-2002, 05:00 AM
Plantraco Plantraco is offline
Improved Climbing - weights on front
With plenty of torque, the Rover can carry some extra weight. There is a slot up front on the Desktop Rover that can be used to carry fishing weights, which move the center of gravity forwards and improve traction for climbing.
Bud
Old 12-21-2002, 10:20 PM
eman1 eman1 is offline
custom title
i just filled the whole front hole area with lead weights. It helped a little with climbing, but doesnt slow down the tank at all.
Old 01-11-2003, 06:17 PM
Treadator Treadator is offline
can somebody post some pics of the slots for fishing weights? i've looked and looked but haven't came across anything
Old 01-11-2003, 06:54 PM
There are some cavities on the very front, just ahead of the "gun" IR Diode.
whats the best formula for rock climbing unknown2 ZipZaps Monster Truck 3 03-30-2005 11:17 PM
question about climbing angle... kehern15 ZipZaps Monster Truck 18 02-18-2005 02:59 PM
Steering improved? ZipRC ZipZaps SE 1 03-07-2004 05:21 PM
New Micro and improved Motorworks Azimov ZipZaps 201 08-02-2003 11:31 PM
Magnet source for improved steering mod DesertJedi Bit Char-G Parts and Hop-Ups 1 10-29-2002 05:19 PM
