Old 12-20-2002, 02:44 PM
gtr2112's Avatar
gtr2112 gtr2112 is offline
just cruisin by.....
improved runtime!!!
i have a nakamichi n racer that i modified the contoller on. i went to radioshack and got an AC adapter plug with 3 pins that shuts off the battery power when you plug it in. i wired it directly to the battery terminal. so now i don't have touse the batteries to charge. i also bought a micro thunder bike and noticed it uses 3 AA's with a 100 mah. so i thought what would happen if i charged my other cars with my nakamichi controller? WOW!!! talk about run time!! i got 17 min first time, and it increased the run time when i used the regular charger. now i get between 15 and 20 min when i use 4.5v and 10 to 15 on 3v. so far no problems with the batts in the cars, so i don't need to upgrade my nicd's.
muscle bound FREAK!
Old 12-20-2002, 04:08 PM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
Thumbs up
Excellent work!
Could you share the details with us?
Part #'s and diagram would help!
Would this be possible on a Bit/MS controller?
MicroSizers Subaru Impreza WRX
Old 12-20-2002, 04:58 PM
gtr2112's Avatar
as long as there's room in the controller it's possible. the jack itself is a little large and you have to make a hole for it. it's pretty self explanitory if you've ever done any regular soldering. you just have to figure out which prong shuts off and solder the batt hot to that. when you get it make sure you get the right plug for it and a 3v AC adaptor 300mah or more. you can't use a 4.5 adaptor on a 3v charger. tried that, fried my controller! best to get a clone that uses 3 AAA's or AA's and adapt that. good luck.
muscle bound FREAK!
Old 12-20-2002, 05:01 PM
gtr2112's Avatar
i forgot, you can also charge dual cell mods with the 4.5 adaptor.
muscle bound FREAK!
Old 12-20-2002, 07:44 PM
DriveWRX's Avatar
Thumbs up Thanks!
Thanks for info, gtr2112!
Steering improved? ZipRC ZipZaps SE 1 03-07-2004 05:21 PM
What's the runtime of an XMod? LCKKN]HT XMODS 5 02-05-2004 11:49 AM
Battery Runtime Tests Namuna Bit Char-G / MicroSizers 25 09-20-2003 09:35 AM
New Micro and improved Motorworks Azimov ZipZaps 201 08-02-2003 11:31 PM
improved range for booster controler? any idea's? microsizer02 Bit Char-G / MicroSizers 2 09-13-2002 06:44 AM
