Old 12-18-2002, 09:11 PM
doctor dole doctor dole is offline
Send a message via AIM to doctor dole
Is this Bit good?
I've heard bad things about the range on this bit char-g. What do you think of it in general?
http://www.toyeast.com/proddetail2.asp?pdtid=ATORC031
Old 12-18-2002, 09:29 PM
Shypo's Avatar
Shypo Shypo is offline
Regulator
i have that car and the range is in excess of 35ft
go fast, be free, with low CC
Old 12-18-2002, 09:50 PM
Rogue's Avatar
Rogue Rogue is offline
Keep plodding
Got it too (got the entire set). No problem here. No cripple cap though.
There is wisdom in a multitude of counsellors.
Old 12-18-2002, 09:54 PM
eman1 eman1 is offline
custom title
dole-thanks for making me cancel the toyeast order just because 1 person said it had bad range....
Old 12-19-2002, 12:57 AM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
Send a message via AIM to Pojo
Once I removed my crip cap on the car, like Shypo said, 40ft.
Old 12-19-2002, 12:59 AM
Shypo's Avatar
Regulator
yeah i forgot to mention it had a cripple cap but even before i took it off it had about 20ft of range
Old 12-19-2002, 08:31 AM
Rogue's Avatar
Keep plodding
Are you talking about the cripple cap on the controller or on the car? My controller doesn't have a cripple cap. Are there any pictures of all of this?
Old 12-19-2002, 10:44 AM
Pojo's Avatar
Corolla Power!
We're talking about car.
Old 12-19-2002, 01:32 PM
Rogue's Avatar
Keep plodding
That's what I thought. Thanks pojo57.
Old 12-19-2002, 02:34 PM
Bryan4691's Avatar
Bryan4691 Bryan4691 is offline
Asia-Link Racing
As you can tell in side pic, I have the same car. I also removed my CC and upgraded my car antenna to 26AWG twisted pair cable. I get 40+ feet. I also have the Pennzoil (27MHz) and get about the same, with similar mods.
Old 12-19-2002, 02:45 PM
shocon2k
No Bit I've ever heard of got 20 feet of range out of the box. Usually its between 5 and 10 feet. Once you put a new antenna on, then you'll get around 20 or 25, and remove the cripple cap and you'll get 25-30. I get 33 feet with a perfect line of sight from antenna to antenna.
Old 12-19-2002, 03:41 PM
Sniper596's Avatar
Sniper596 Sniper596 is offline
I'm 1337 r/c'er :)
that's odd, i get 20-30 feet from my microsizer/bit out of the box. but i don't think there's a crip cap inside the controller, i can't seem to find it . I have two controllers with same frequency, and with the same car one gets a better range than the other so, there's got to be some more caps i haven't heard about.
Old 12-19-2002, 05:51 PM
cflcr's Avatar
cflcr cflcr is offline
Bit Gothic
i've got this bit, crip cap on contorller and car, i've removed both and my range is really good 30+ feet, and it comes with a 2.6 stock motor
Nissan Skyline Loctite Zexel GT-R [special ed.]
Comparison.....Bit, Lxxx, Precious, Bensu....... DarkTari Bit Char-G / MicroSizers 3 02-23-2003 12:36 AM
Can Bit Char-A be modify like Bit Char-G? Racemonster505 Bit Char-G / MicroSizers 5 09-25-2002 01:01 AM
