Old 12-16-2002, 12:40 PM
ejaf ejaf is offline
Anyone order 1/3AAA 150maH from Batteries America?
FYI for you guys/gals...
Ordered the 1/3AAA nimh 150 maH batteries from batteriesamerica.com the other day. They came pretty fast, but here's the kicker:
They are from the company AP, and they are tagged as 1/4AAA, not 1/3AAA. Pulled out the ol' micrometer, and their height is 2 mm shorter than the stock 1/3AAA (13 mm instead of 15mm).
Although the price was right (2.25 per), they will not just swap in, since they are not making solid contact with the battery holders.
When I called the company and mentioned the 2mm difference, I was told that the battery sizes are not an "exact science" (meaning that there is no set worldwide standard). He was willing to refund my money, but it's probably not worth it for me.
I could probably shim them so that they fit OK, but has anyone else received 150 NIMH's from companies other than AP, which the height was equal to stock? I also didn't know that they made 1/4AAA's with 150 maH.
Any opinions appreciated.
Old 12-16-2002, 01:29 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Seems like a nice find. Superglue the metal contacts to the chassis and just bend them in to meet the battery.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 12-16-2002, 03:09 PM
chp's Avatar
chp chp is offline
I used a little copper shim on mine, ejaf. Place it between the battery and the contact. Haven't had a problem with it. Extends the run time nice, especially after a pcb swap.
You're jealous because the voices only talk to me :P
Old 12-16-2002, 05:01 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
you could put a glob of solder on either end to make it fit as well. they are cheap enough
Old 12-16-2002, 07:39 PM
thanks...
Thanks for the input, guys. Will do. Now...where to find copper shims? Hmmmm...trip to basement in order.
Old 12-19-2002, 02:30 PM
Stride's Avatar
Stride Stride is offline
Bard
if your cells have tabs you just need to fold the tab back over itself and fanfold it a few times...
it'll fit fine
What is the shelf life on batteries?, 150mah novastar512 Bit Char-G / MicroSizers 12 02-24-2003 11:18 PM
hmm.. how come the 150mah batteries r smaller than the 50 mah ? karlos Bit Char-G Parts and Hop-Ups 2 12-05-2002 07:39 AM
150maH batteries actofgod Bit Char-G Mods and Projects 17 11-17-2002 09:46 PM
100mah + 150mah dual batteries? BLWNSTNG ZipZaps 4 10-20-2002 02:17 PM
