Old 12-18-2002, 08:42 PM
VERTiG0 VERTiG0 is offline
hay u guys whats goi-
Send a message via ICQ to VERTiG0
Bit Char-G charging light not working...
The charging LED of my 35MHz Skyline GT-R History set isn't working. It'll flicker sometimes, but 99% of the time it won't come on at all.
Any ideas? There are no loose wires or anything in the controller.
Skyline GT-R History Set
Many people never stop to realize that a tree is a living thing, not that different from a tall, leafy dog that has roots and is very quiet.
Old 12-18-2002, 09:03 PM
Rrickatic Rrickatic is offline
Does the car still charge when the light doesn't work?
My Mach 5 has to be on the charger just right.
Old 12-18-2002, 09:10 PM
Yeah, it apparently charges just fine.
Old 12-18-2002, 10:31 PM
Anybody else? Any clue whatsoever?
Old 12-19-2002, 08:56 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
ive had problems with a few cars where the charging posts in the car come loose and slide back. you gota push em back where the terminal meets the battery. its easy
Old 12-20-2002, 08:10 PM
BackInBlack's Avatar
BackInBlack BackInBlack is offline
MyMicrosUnderTheFridge...
It could be a cold solder joint on your LED. Try wiggling it while you are charging, and see if it lights. If it's flakey, open up your controller and re-solder the LED pins.
Old 12-22-2002, 06:13 AM
HexiumVII HexiumVII is offline
in fact, BOTH my Skyline history sets don't light up. I got them totally different places too, online, and locally. When i test them, i only get about .5 volts, so i think there is something wrong. I opened them up and found that shorting out two things to get it to work. Its really weird.
Old 01-08-2003, 11:00 PM
bitchargen
BACKINBLACK, DO U STILL NEED THE 49,HZ CASUSE HOBBICO SEND U A 27? I GOT THE SAME PROBLEM, BUT OTHER WAY AROUND! I WILL SELL U A 27MHZ! EMAIL ME!
Old 01-09-2003, 12:20 AM
spikeymike218 spikeymike218 is offline
TinyRC Sith Lord
could be something as simple as putting in some new alkaline batteries.
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
panther to bit char parts zakkstyle Bit Char-G / MicroSizers 1 06-25-2003 12:08 PM
Town for Bit Char G Seb123 Bit Char-G / MicroSizers 2 03-30-2003 11:22 AM
what brand to use in Bit Char G controllers striderpunk Bit Char-G / MicroSizers 0 08-05-2002 12:38 PM
New Bit Char Bodies? NSX, Supra, etc...... mike_diaz19 Bit Char-G / MicroSizers 7 06-04-2002 05:20 AM
Help Fast!! Price & Quantity Of Bit Char.... mike_diaz19 Bit Char-G / MicroSizers 1 05-25-2002 06:46 PM
