Old 12-15-2002, 10:07 PM
pakiplaya
Cripple Cap On 27mhz Skyline
please, please, i beg anyone, i dont know where the cap is in my controller, anyone else have the 27mhz skyline(white) and found it?
Old 12-15-2002, 10:16 PM
shocon2k
www.questformadness.com has all the details on pretty much every mod you can do.
Old 12-15-2002, 10:18 PM
bill's Avatar
bill bill is offline
I are smart....
bwahahahaha......
That's the same answer he got before
Note: If someone has the same car as you and has found a cripple cap, it doesn't mean you will have one. It depends on the revision of the board on the controller. The newer controllers do not have a cripple cap.
Old 12-15-2002, 10:24 PM
pakiplaya
on ausmicro.com and questformadness.com both pictures are the same as my controler, but the cap isnt there in the same location, this site doesnt help
Old 12-15-2002, 10:46 PM
pakiplaya
help?
Old 12-15-2002, 10:50 PM
bill's Avatar
I are smart....
Obviously, you're not reading my replies.....
If someone has the same car as you and has found a cripple cap, it DOES NOT mean you will have one. It depends on the revision of the board on the controller. The newer controllers DO NOT have a cripple cap.
Old 12-15-2002, 11:34 PM
1llusI0n 1llusI0n is offline
BitOnline GM
Send a message via AIM to 1llusI0n
but then why do they still have **** for range? i have a white 27 skyline and it wont run more then 3 feet infront of me
Old 12-15-2002, 11:37 PM
aero aero is offline
What It Is To Burn!
if they can cripple the range without the use of a capacitor, then they are not going to use one, that is why older bits have them and some or most newer ones dont. there are other mods you can do to increase the range....
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
Old 12-16-2002, 12:16 AM
DarthRacer's Avatar
DarthRacer DarthRacer is offline
Sith Bit Racer
Send a message via AIM to DarthRacer
Why are you so hell-bent on removing the crip cap?
It seems it is giving you more trouble than its worth.
The best range mod I have done was simply to increase the length of the stock antenna by re-routing the anntenna to go directly out the back of the PCB, instead of it being routed to the front and then over the PCB. I have a 27MHz S2000 this works great on.
- Calsonic
Old 12-16-2002, 11:32 AM
shocon2k
I used to get crap range on my 27 mhz skyline as well (microsizer, USA bit release) so at first I rerouted the antenna like Darthracer did, and that gave me about 6-8 feet of range over the initial 5-6. Then I said screw this and took out that little antenna and soldered an 8 inch 22 guage copper wire, uninsulated, in its place, and put a little loop on top just so it looks extra sexy. That boosted my range to about 20 feet, no joke. Then, I removed the cripple cap from the car itself (be CAREFUL doing this...www.questformadness.com has the EXACT one to remove, and its accurate for all bits and microsizers I believe, not so sure about clones) and that got me about 25-30 feet, depending on where I use the car. Needless to say, I'm quite pleased with the results. My controller did not have a cripple cap, its one of the newer ones. But definately replace the antenna and you'll be happy with what you get.
Old 12-16-2002, 05:14 PM
pakiplaya
THANK YOU! SOMEONE HAS A BRAIN IN HERE! AND IS TAHT ANYTENNA A CAT5?
Old 12-16-2002, 07:08 PM
bill's Avatar
I are smart....
You calling the rest of us stupid???
The reason we was not being very helpful was because you were going on an asking spree (3 - 4 times of the same question on different threads). Don't say you weren't because i'll dig up the threads for you. We were sick of you. Hell, i'm so sick of you that I know the answer to your headlight mod question but i'm not going to help you anymore. You'll have to wait for the "smarter" people to help.
Have a nice day.
Old 12-16-2002, 10:25 PM
shocon2k
The antenna is not made from Cat5, its just your basic run-of-the-mill 22 guage non-insulated copper wire, can be found at hardware and craft stores for about $3 for a spool. And its rigid enough to stand up by itself, but won't weigh down the car, and can bend easily enough to be practical. Best bang for the buck for your car.
Old 12-16-2002, 10:28 PM
What It Is To Burn!
not true.........cat5 or category 5 network cable is a solid copper wire that can be bought at home depot, radio shack or a local computer store. Inside a networking cable, there are 8 category 5 copper wires. so, a foot of network cable actually gives you about 8 feet of copper wire.
Old 12-16-2002, 10:33 PM
pakiplaya
more people have brains here!
Cripple Cap. soggyrice.mMmMm Bit Char-G / MicroSizers 0 03-15-2003 09:47 PM
u have a 27mhz skyline(white) cant find cripple cap pakiplaya Bit Char-G Mods and Projects 1 12-16-2002 03:18 AM
Where is the cripple cap on the 27mhz skyline(white) pakiplaya Bit Char-G / MicroSizers 4 12-15-2002 11:32 PM
US Microsizer Cripple Cap. Is there a difference? efferfax Bit Char-G / MicroSizers 0 10-02-2002 02:16 PM
Possible Cripple Cap.. Look at the pic! retroicon Bit Char-G / MicroSizers 3 09-08-2002 12:56 AM
