Old 11-19-2002, 07:26 PM
R|cer ><'s Avatar
R|cer >< R|cer >< is offline
R|cer ><treme
Got this one from an anime mag. Its the 'Mobile' Acura NSX. I know its not the standard packaging but all of the Japanese Kanji is the same on it...if it is a knock off it doesn't matter to me...it smokes every other car I have. Here's the packaging it came in...
I don't want the world... I just want your half.
Old 11-20-2002, 07:20 AM
actofgod actofgod is offline
Bit Surgeon
Bitmod1 motors
Has anyone taken a look at the new Bitmod1 custom-designed motors? Supposedly they have more torque than the others and a 3.5 Bitmod1 motor can trash a regular 3.8 motor!
"I was amazed with the speed of the motor, along with the handing. I could run the motor full blast and still make turns. My wife and I raced side by side, my car with the 3.5 motor and hers with the 3.8 motor, and I was amazed to find that the 3.5 blew the 3.8 out of the water. On a straight away of about 15 feet, the 3.5 beat the 3.8 by at least 5 feet. I was very impressed with this motor. After this test I tested the 3.2 motor against 3.0 and was again amazed to find that the BITMOD1 motor out performed the 3.0 by at least 5 feet again. The only drawback that I found was that I couldn't fit either motor into my microsizer"
I see 3.2 and 3.8 on their site also. This looks really promising. Only downside is they're a little too big to fit a microsizer (so they say). I'm wondering if they're about the size of a ZZ motor then? Someone tried these yet?
Here's the site:
http://www.bitmod1.com
Here's another review:
http://groups.msn.com/TheAdmiralsLai...torreview.msnw
Old 11-20-2002, 10:09 AM
rud0g rud0g is offline
You can't handle the truth....
I don't know what you are looking to do exactly,
But here in Arizona some friends and I have been experimenting with 'Top Fuel Drag Bits'.
If you check smoovy.com you can track down 5mm + 8mm motors that will do up to 100,000 rpm with torque that is comparable to the 2.6 motors. We have been working out a chassis/body design based on 1/64 scale.
The logistics of fitting 4 NiMH cells + pcb into these things is kind of a nightmare, and the cost is prohibitive, we are talking $235us for a single motor.
If you're not living on the edge, then you're taking up too much space.
Old 11-20-2002, 11:58 AM
Bit Surgeon
So it's basically a 10.0 motor? But with 4 cells, even a 2.2 or 2.6 might be that fast, and the bitmod1 motors might have enough torque to equal this one. It'd be fun to experiment, but dang.. $235 is a lot for a tiny motor. While you're at it, why not get the one with the backshaft and make a 4wd bit like the mini-x design, lol.
BTW do you know what size the Bit motor is? 3mm, 5mm, or 8mm? It looks like 3mm to me but I suck at mental metric.
Old 11-20-2002, 05:56 PM
henry's Avatar
henry henry is offline
13B REW
thats a motor from dks. dks also have 2.4, 3.1,and 3.4.
Old 11-20-2002, 07:04 PM
R|cer ><'s Avatar
R|cer ><treme
FYI...
Drift King is a good guy. I've bought a few items from him... Never through eBay though. Drift King's website
Old 12-09-2002, 08:02 PM
hiero's Avatar
hiero hiero is offline
^STREET RACER 209
all i have is the nos and turbo and a microsizer 2.6 and the 2.6 smokes the turbo and nos motor i dont know maybe i just got a good engine.
I think your underestimating my snekieness sir.(quote from Mr.Deeds)
Old 12-12-2002, 10:33 PM
BMW325 BMW325 is offline
DKS 2.6 ZZ?
as anyone put the DKS 2.6 ZZ motor in a bit?
chassis=Tomy 35 MHz 2-Spd
body=Silver Nissan 350Z
motor=ZZ NX
(Lambo set in the mail)
Old 12-13-2002, 09:12 PM
Ghost of Akina's Avatar
Ghost of Akina Ghost of Akina is offline
da da dum da dum da da
hey ricer it looks like you have a clone becuase the PCB cap of every other real bit doesn't look like that and bit char-gs dont come in 49 mhz only microsizers do (bit char-gs come in 27,35,45,57)
and i haven't seen those bodys on the packaging ever and the mobil honda nsx-r only comes as a body set not the whole thing i believe
"Do you want a new Bit Char-G
WELL I DO TOO!!!!!!!!!!"-me
"i'll let you win, on one condition beat me"-me
racing down akina
Old 12-14-2002, 04:49 AM
hiero's Avatar
^STREET RACER 209
Originally posted by datamonster
yea, the green gears are made for Bit Racers or, as it is known in the States, Hot Wheels K.I.T. Racers. They can be modified for Bit Char-gs with a litttle bit of cutting on the axle.
Dude bits arent K I T racers in the states.Micro sizers is the U.S. bit char g.
Old 12-14-2002, 10:16 AM
dude read the god damn post every body knows that, dip**** read it, it says BIT RACERS=KITT RACERS and MICROSIZERS=BIT CHAR-G
man I'd be surprised if you knew what a Bit Racer is
racing down akina
Old 12-14-2002, 06:38 PM
JBit's Avatar
JBit JBit is offline
go Go GO, JBit Mifune!
So what do you think, drift king? is your new DKS 3.4 better than the OEM 3.8 - in accel, torque, top speed?
The Mach w/DKS 3.4 Darkside Rotor.
Old 12-15-2002, 09:52 AM
R|cer ><'s Avatar
R|cer ><treme
Well, I'm not DriftKing...but, I just had a 3.8 go out on me. I bought (2) 3.8s recently. One for myself and one for a friend as a Christmas present. Mine worked for 1 full charge. Second charge...well, the second charge is a different story. I can't even get it to rotate without an axle installed.
I bought mine from tinyrc.com. Tinyrc.com is really good about swaping out defective items for new ones, so no worries there.
When the 3.8 ran the first time-
It was slightly faster on the top-end than the DKS 3.4 but, it had less torque. It crawls the first few feet. Proper gearing is a must! seemed to be ok, but I wouldn't tweak much beyond that.
Old 12-15-2002, 11:10 PM
JBit's Avatar
perfect answer, thanks! i'm thinking about getting new motors too so that response helps.
Old 12-16-2002, 04:28 PM
R|cer ><'s Avatar
R|cer ><treme
No prob! Glad to be of some assistance.
Very fast engine. Chaos Fire XMODS Mods and Projects 1 12-28-2003 09:15 AM
Fastest engine poll ml22 Bit Char-G / MicroSizers 10 03-03-2003 02:24 AM
1,0 engine problems M@rk Bit Char-G / MicroSizers 1 12-24-2002 03:19 PM
Three Special editions, 2 Microsizers and some engine work. AceQ Bit Char-G / MicroSizers 3 10-23-2002 09:42 PM
Prb with 3.0 engine Seb123 Bit Char-G Parts and Hop-Ups 1 09-12-2002 01:31 PM
