Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM SP
Old 11-29-2002, 02:54 PM
was ist los?'s Avatar
was ist los? was ist los? is offline
SpeedFreak
Removing Rims
I have a hard time taking off the rear rims. I guess all the lubricant on that giant O-ring came off. Once, the setscrew even came off! I have tried ceramic grease and motor lube. i have also tried some oil with teflon. What do you guys use to take off your rims.
Old 11-29-2002, 06:10 PM
gertman's Avatar
gertman gertman is offline
I just use the grease that came with the kit. Don't just grease the o-ring, do the whole hub. I suppose also you could try graphite filings.
-Engineering Manager
Old 12-14-2002, 11:26 PM
Siress Siress is offline
Send a message via AIM to Siress
I have a DRR and I am wondering what the best replacement is fot the stupid small o-ring on the axel for the diff. tention.
Old 12-15-2002, 11:26 AM
gertman's Avatar
I just guessing here, but maybe ANOTHER:
stupid small o-ring
Why? Have u lost yours? Has your o-ring offended you? Did you want your diff to be adjustable? Do you just want to have an o-ring-less car?
Old 12-15-2002, 05:37 PM
:slapingforehead:
lol, jk
Because the o-ring will eventualy get cut and because it doesn't allow you to adjust the ball diff. tention as well as I would like.
Old 12-15-2002, 09:23 PM
gertman's Avatar
That's funny, 'cause mine's been on for 1yr plus!!!
Maybe a couple washers or a small spring would give some adjustment?
Old 12-19-2002, 10:14 PM
After hearing the plans of a execlent racer at the track tonight I have decided to make a new rear axle. I will have it the same length and width but insted of having a screw going into the axle I will die the outer edge and put a lock nut on it. That should work better.
I fubed up while cleaning my car before a race. I was cleaning and oiling the rear axel parts after discovering that my o-ring was pan-caking out making my diff. be really lose and I was thinking to much about how to fix than what I was doing and lost every bearing out of the thrust bearing but 2. :-/
At the end of it all I decided just to do a timperarey rigging of it and put 2 small washers to replace the o-ring and REALLY greased up the thrust disk so it would slide good. Then I put loctite on the diff. screw and locked it down. only until I get my other one going.
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
custom wide rims broke ess supra XMODS Mods and Projects 1 07-18-2005 07:59 PM
New DUB City Rims DriveWRX Bit Char-G Parts and Hop-Ups 20 12-08-2003 09:43 AM
Cool Alloy Rims cj1267 ZipZaps 0 05-09-2003 12:17 AM
