12-05-2002, 11:03 PM
I are smart....
Lxx 3.0 motor vs Bit Char-G motors
So how does the clone LXX 3.0 motor compare with the bit charG motors? Is the LXX 3.0 comparable to the bit charG 3.0? (I did a search but couldn't find the answer)
12-06-2002, 12:21 PM
BiT TuNeR
never heard of lxx...but it depends on which bit motor..if it is 3.0 vs 3.0 it would be pretty close..
*GoOsEmAn*
12-06-2002, 01:04 PM
assuming that its being run on the same gears , have same weight, and same power source.
1988 Mazda MX-6 GT,140000.Current Project: Restoration of Vehicle/Minor Mods.
Fixed:Broken Trunk Latch,Broken seat,Broken seatbelts, oscillating vents.
Broken:Bad CV joints,Bad paint & Body,Squishy Brakes,Bad windows (parts in),Slow sunroof,Cracked Windshield,Oil leak,Bad seatbelt spring,Cracked Corner lens,Boost leak,Cracked dash,Exhaust manifold leak.Mods:Blitz Turbo Timer,Indiglo Gauges w/ glowing needles, Pioneer CD player (to be installed),Adamturbo mod chip (to be installed).
12-06-2002, 03:39 PM
I am still wating for my 3.0 tomy to arrive but I had a lxx car and it was fast. However I will follow up on this when the time comes.
12-07-2002, 03:05 PM
Bit Drag Racer
LXX 3.0=sadly slow
Bit 3.0=sadly fast.....lol
12-07-2002, 03:29 PM
i have a lxx car, which comes stock with a "3.0" but it is not nearly as fast as the tomy. in fact, my stock microsizer with a 2.2 is faster than the lxx. but i would still recommend the lxx because it handels very well compared to the tomy.
I will ALWAYS win...
H
o
n
d
a ...will never loose
12-07-2002, 05:07 PM
lxx
I had a lxx and when I first got the car it was very slow so slow I put it down and din't want to play with it anymore. Then some things happen I out of no place decided to change change the body and wala the dam thing flew across the living room floor.
When I put baCK the old body it did it again as slow as a turtle.
So do youself a favor and find a ligft body and you will see a major difference.
12-12-2002, 02:28 PM
other body's
I tried other body on the car it was the same. All the heavy bodies weight the car down. When ever I'm racing I allways change the body and tires.
12-15-2002, 12:18 AM
I've got:
LXX 3.0 and,
microracer(bit char-A) with a 2.6 and green gearing.
The 2.6 with gearing smokes my LXX. Not just a little faster, but runs circles around it. 2-3 times faster at least. I was disappointed. So, I've ordered a bit 3.0 and also a genuine Char-G brand car with the booster 2 speed. Now to wait and see what happens when I mix and match.
12-15-2002, 12:51 AM
Yeah a friend of mine has and LXX with te 3.0 and smoked my 2.6 KIT Bit Char G. The motor in the lxx is weird. No tab like on the tomy or kit or micro q just a round plate out the back in the dead center. The lxx is also very loud and the paint immedately started peeling off. The tires though are amazing.
Bit Char G, Blue Skyline GT-R, 2.6 KIT
Microsizer, WRX won microsizers.com
Micro Q, F360 Modena, Working on it
Castrol Supra Body, Mobil Nsx Body
12-15-2002, 11:10 PM
I are smart....
damn, forgot about this thread
I guess the short answer is that the LXX 3.0 is more like a Tomy 2.2 or a Tomy 2.6 if the shell isn't on the car... LoL
12-16-2002, 01:29 AM
I own you
i got some lxx bits, and the motors are loud and slow. They got white end caps. They got the speed of like a 1.0. (it was special racing edition bits)
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
12-16-2002, 11:14 AM
It's not the car but the cover I had the same problems. My car ran like a dead horse untill I took of the cover and wala. Try it.
12-16-2002, 08:37 PM
I are smart....
Well, what good is running a car without the shell....
12-17-2002, 11:45 AM
If you race it everything. I put a old panther body on the car and it ran 2 times faster. If you race the body means everything.
