Old 12-12-2002, 01:04 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
No more 5 o'clock shadow
I've shaved my Zip clean. After experimenting with few clone PCB's I realized that I could shave down the walls and lay the PCB flat on the chassis. I did this for two reasons. I wanted to reduce some weight, cos I plan on putting in an extra battery and I wanted to be able to put in some bucket seats I pulled out of a import tuner die-cast car. Here's the first pic.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 12-12-2002, 01:07 PM
Stridex's Avatar
Chunk
Second pic
Second Picture
imaginary friend.
Old 12-12-2002, 01:09 PM
Stridex's Avatar
Chunk
Last Pic
imaginary friend.
Old 12-12-2002, 03:43 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
That's very interesting. Faster PCB and lighter chassis. That Zip is gonna fly! Now, if you could only use the original Zip controller, I'd be doin it myself. I got a gutted Motorworks clone sitting here with a good donar PCB.
Old 12-12-2002, 03:46 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
dude you gota lota time on your hands. you should post some video of them driving after you are finished.
Old 12-12-2002, 04:23 PM
BigPimpin BigPimpin is offline
Fugative
those "modifiers" have a lot of usefull parts in them
Old 12-19-2002, 03:54 PM
Stride's Avatar
Stride Stride is offline
Bard
don't be mean to Stridex. he has sacrificed to much for the advancement of toys. send him your love.
Old 01-08-2003, 06:21 PM
mustang_steve's Avatar
mustang_steve mustang_steve is offline
the "too many tires" guy
Send a message via Yahoo to mustang_steve
using original controller can be done
Just get a matchinig frequency microsizer. Since they are setup for use in the us, much like the zips are, you can most times swap and not even have to do any pot setting.
I did this to my pt cruiser, used a 49mhz microsizer, and its bee working fine. Any controls that were reversed, I changed the car's wiring to handle. i'm seriously considering doing what stridex has done, but leaving a small bit of wall for structural reasons. I've also been shaving the heck out of the sides of my FF eclipse body as well as aesthetic junkn (cut out the holes that should be cut out, including that duct on top of the car). It's quite a bit faster, but its been killing batteries, so I've put the nicd from the microsizer into it, and i think im seeing a bit better runtimes.
I could have had a dud battery though, who knows.
BTW use the microsizer tires in back, and zip tires up front. it helps handling quite a bit, and just plain looks better.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
Is that a shadow, no its an Xmod danny_v_l XMODS Gallery 15 01-19-2004 11:49 AM
