11-14-2002, 01:58 AM
dual cell problem ....... again
well i did the dual cell mod it was just a bit of a sloppy job because it was my testing chasis but i did it correctly. i thinks it just how it should be. i give it about 6 multipul charges ( all in 1 go controller mod ) and for some reason my car is super fast for about 8seconds then just dies out. what is wrong??
im using dual 150mah nimh cells by the way
11-14-2002, 02:57 AM
Toy Collector
did you modify the charger as well? as they mentioned in QFM
NSX-R , FairladyZ33, Auto Modellista, AE86 Trueno,
Calsonic R34, R34(WHT), Evo VII(YLW)
11-14-2002, 05:03 AM
yeah i modded my controller to get rid of the timer....... but still i dunno wats up
11-14-2002, 09:23 AM
Check all of your connections. If you did it like the instructions at QFM, then the battery in the body might be grounding itself. If that's the case then you're burning up all your juice to heat up the wire running between the batteries.
11-14-2002, 10:23 AM
yeah ok mate ... so whats my soloution? i followed the QFM instructions. also wat does grounding mean.
11-14-2002, 01:27 PM
Go back and make sure that all of your wires/connections are only touching things they are supposed to touch. It sounds like you might have a short. With the QFM instructions, there is a bit of a tendancy to not totally insulate the negative pole of the battery in the car. That makes the batteries just fight each other and drains all of the charge. But it could be any one of your connections if they aren't properly insulated.
11-14-2002, 04:21 PM
thanx 4 the help guyz ..... ive absolutly fu**** up my chasis so ill just wait till i recieve my new 1. dont worry it messed up along time ago
12-08-2002, 09:12 AM
ive just done the dual cell mod and got exactly the same proble, - lightening fast for 10 seconds then really slow- ill check connections...
12-08-2002, 09:21 AM
i found the prob AGEZ ago mate
you gotta build a stand alone charger.
think like this........ there are 2 batteries in the controller to charge 1 battery in car. u need 4 batteries in charger to charge 2 batteries in car! 2 batts dont push out enuff voltage to charge 2 batts
hope this helps!
12-08-2002, 09:53 AM
really is that the problem?? Would that explain the 10secs of supercharged bliss then back to normal slow pace??
12-08-2002, 09:56 AM
yup exacly!
12-08-2002, 10:15 AM
cool thx very much, im gonna get me one of those 4 battery holding things to wire my charging pad up 2
thx
