12-06-2002, 12:07 AM
Light wiring
I have 4 LEDs and two 3V cells (and a switch)
When I wired it up (in different ways, with both one or two batteries, etc) either the headlights or the tail lights could go on. not both.
Once i got both to go on but then the headlamps would get dimmer until theyre completely off.
Anybody know how the proper circuit goes?
12-06-2002, 01:24 AM
Runs with sharp stuff
Are you trying to have them all on at the same time or just the headlights on when going forwards, and the brake lights on in reverse?
12-06-2002, 08:11 AM
all at the same time
12-06-2002, 10:31 AM
mogi's godfather
lights
you had the
polarities
(+ and -)
reversed when
only one pair would light
as for the dimming
some leds require more than 3v
especially blue and white
try another battery
or just use headlights
i use yellow and red and
thats usually ok
good luck
oink
12-06-2002, 11:33 AM
i guess its the battery, thanks for the help
12-06-2002, 04:27 PM
Well, they didn't really fit in my car, but I basically made 2 circuits (one for the head and one for the tail lights).
12-06-2002, 09:16 PM
try putting putty under the light to block the light from escaping through the bottom
12-06-2002, 09:17 PM
for if the light escapes then it shall mean certain doom for all of us
HAHAHAHAHAHA im insane in the membrane! i love sugar ever so much
12-07-2002, 04:09 AM
Just wire all the LED's in parallel. In other words + to +, - to -.
12-07-2002, 04:16 AM
That celica with light mod looks very cool. What components do u need, i'd love to make my celica look like that!
12-07-2002, 04:48 AM
If the lights are mounted behind the headlight (i.e not cut through the bodyshell) do you have to remove any paint from the inside of the BIT or does it woek fine without??
12-07-2002, 05:44 AM
You should remove the paint first. On some of the light kits that are available for sale, it comes with some paint remover and q-tips so that you can take the paint off. Most of the newer Bit bodies have the paint on the underside of the body. It's a different story when the paint is on the outside.
I'm out like the fat kid in dodgeball.
12-07-2002, 10:18 AM
I think I tried it parallel and that's when my headlamps dimmed out.
12-11-2002, 09:12 AM
It will: The red LEDs will suck the voltage down to their level, leaving a low voltage for the whites. Stick a series resistor on the pair of red LEDs (maybe you get away with one resistor for 2 LEDS, maybe you'll need 1 each) and then try again
You may have to cut-and-try the values to get it to work correctly and not suck the voltage down, while still retaining brightness.
Mike
