Old 12-03-2002, 09:55 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
How does it make it better? And, have you tried it?
Old 12-04-2002, 12:40 PM
seizurebot[rdf] seizurebot[rdf] is offline
megazord
yes friend megazord. that is what saran-wrap does. it is electric so it will make you go very fast. electric is the thing that is fast in your engine like zoom.
RDF 4 LiFe
Old 12-04-2002, 01:45 PM
TemjinNeo78's Avatar
Bit Drag Racer
i havent tried it....i did it lol and the range is excellent, a big step up.
Old 12-04-2002, 03:59 PM
xatu's Avatar
So, I would just wrap it around my antenna? Or, are you just yanking my chain?
Old 12-04-2002, 05:08 PM
Bit Drag Racer
i was talking about the cat5 mod.
Old 12-04-2002, 06:08 PM
darkarchez's Avatar
darkarchez darkarchez is offline
TinyRC - Lancer Racer -
i did it.... copper wire super 25 feet baby!
Old 12-04-2002, 06:42 PM
xatu's Avatar
Oh. BTW, nice car darkarchez!
Old 12-05-2002, 12:24 AM
darkarchez's Avatar
thx man.... hey check this out .... i made a quick add .... it gave me 10 more feet by adding foil into my wire... omg dam man it had good max range when i put this piece of foil onto it check it
Old 12-05-2002, 01:25 PM
darkarchez's Avatar
ok this foil mod ddint work that much.... but inspired of caver01
spring mod and foil mod... it really inspired to use a spring wire when i went outside and tested this mod , i recieve good results .. a small piece of wire gave me a big 53 feet!!! i was surpised of this feet for a smal silver spring wire i think the spring wire would give you better results than the copper wire.... because it gave me a big feet for a such small amount of spring
Old 12-06-2002, 04:07 PM
xatu's Avatar
So, basically, you have a spring wire for the antenna, and you put tinfoil on the INSIDE of your car?
Old 12-06-2002, 08:04 PM
dumbnewbie dumbnewbie is offline
I might have missed it because 11 pages o fthis thread got a bit long, but has anyone tried using a copper pin to draw a long antenna inside the body of the car? If I remeber right Radio shack used to sell a copper pin that could be used for touch up work on pcb's. It would seem like this is the easiest way to route a long path of copper inside the car.
Old 12-06-2002, 08:57 PM
DavidDeLaurier DavidDeLaurier is offline
Send a message via AIM to DavidDeLaurier
That has ben mentioned, but I don't know if it has been tried yet.
I used a spring and got a range of about 67 feet. (hard to measure with a normal measuring tape.
Old 12-06-2002, 09:54 PM
xatu's Avatar
So, jsut a standard spring straightened out and soldered onto the chip works awesome?!?!? I will try that
Old 12-06-2002, 09:56 PM
xatu's Avatar
Lol, I got one problem. Would I just use a spring out of a pen? Or, would I have to find another one?
Old 12-06-2002, 11:29 PM
darkarchez's Avatar
well what i did is that i use a the led pencil ones you know the ones that are big... but before braking the led pencil be sure to make sure it is long enough before u stretch it.... i got mine off a led pencil.. i strecth it and soldered it on... it took a while before i got to solder it on because it stiffness totally irratating when u cant put it on.... but yeah when i went outside it was powerfull enough to go 53 feet.... with the foil mod...
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
Alternate Soldering Ideas??????? tory_103 Bit Char-G Mods and Projects 4 12-23-2002 08:49 AM
TallgeeseIIII's Bit Char-G Ideas & Concepts TallgeeseIIII Bit Char-G Mods and Projects 8 12-13-2002 02:32 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
