Old 12-02-2002, 01:21 AM
darkarchez's Avatar
darkarchez darkarchez is offline
TinyRC - Lancer Racer -
about the copper wire... how thick or thin does it have to bee
Old 12-02-2002, 01:23 AM
darkarchez's Avatar
i tried a mod of 2 copper wire twistd and solderd,,, but it didnt give me any reception , does it matter when you twist the two copper wires??? or does it matter when i accidenatally putten a bit more led on to the board?
Old 12-02-2002, 05:35 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
i am gonna install a new antenna. I wanna know do u actually have to solder it on the chip cant u just cut the stock antenna in half and strip it then attach the new antenna??? I can do both but the second ones is a lot easier! LOL
Old 12-02-2002, 06:02 PM
xXx_Vegito_xXx's Avatar
xXx_Vegito_xXx xXx_Vegito_xXx is offline
if u just solder it to the origanal antenna and u were trying to put a copper wire on it it would be floppy cuz of the weight
Specs
custom paint
Honda s2000
3.0 motor (came as stock motor)
medium tires
Old 12-02-2002, 06:08 PM
r u sure u are using copper. i don't think it would matter if u twisted 2 together.
Specs
custom paint
Honda s2000
medium tires
Old 12-02-2002, 06:09 PM
Question
where did u get this wire?
Specs
custom paint
Honda s2000
medium tires
Old 12-02-2002, 06:21 PM
TemjinNeo78's Avatar
Bit Drag Racer
cat 5 copper wires can be aquired at your local radio shack
Old 12-02-2002, 06:45 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Does it matter how long the wire is, if it is copper? My antenna just recently broke off, and I put some copper wire on, and it gets crappy range. The wire is about 2 inches long-is that long enough?
Old 12-02-2002, 07:01 PM
Bit Drag Racer
2 inches is def. too short
Old 12-02-2002, 09:49 PM
xatu's Avatar
What should be the minimum length? About 4-5 inches?
Old 12-03-2002, 12:24 AM
darkarchez's Avatar
i used a wire copper wire.... this is the one on the inside of the wire of my eletronic burnt out solder iron i opend up the wire and took the copper wire thats in it... well i got a new wire that i found on the house imm going to test it soon
Old 12-03-2002, 02:27 AM
caver01's Avatar
caver01 caver01 is offline
This is getting ridiculous. You wanna fix a broken antenna, get some wire, stick it on. What kind? Who cares. Make it match the original. You wanna experiment with something, try it. If you get good results, post here. Geez Louise.
Old 12-03-2002, 01:38 PM
Bit Drag Racer
its not experimenting, its proven, the cat 5 copper wire does give yo better reception that the stock wires, and 4-5 inches is perfect is you want a great range.
Old 12-03-2002, 04:02 PM
xatu's Avatar
Hmm...I think I will just unsolder the copper wire I put on that is too short, and put another one on! YEA! That's what I'm going to do!
Old 12-03-2002, 08:04 PM
seizurebot[rdf] seizurebot[rdf] is offline
saran-wrap makes the antenna better
RDF 4 LiFe
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
Alternate Soldering Ideas??????? tory_103 Bit Char-G Mods and Projects 4 12-23-2002 08:49 AM
TallgeeseIIII's Bit Char-G Ideas & Concepts TallgeeseIIII Bit Char-G Mods and Projects 8 12-13-2002 02:32 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
