Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Combat Digi Q
Old 11-30-2002, 07:32 PM
GrEenGoBlIn GrEenGoBlIn is offline
Send a message via AIM to GrEenGoBlIn
bad motor?
i was running my tanks around and noticed that after a few continuous runs i noticed the left motor making more noise than b4, even with both sets of gears lubed. Also i noticed the car always pulling to the right and setting teh trim didnt help, also i swithced the treads and no difference was noticed....blown motor?...i just bought them about a week ago and if that is the problem can i buy a replacement and jsut solder it in myself?
thanks
Old 11-30-2002, 09:32 PM
BillyBonz's Avatar
BillyBonz BillyBonz is offline
You say the tank pulls to the right? That means the right motor is not going as fast as the left. Give this a try...with the treads on the tank, flip it over and hit forward. Hold you finger on the center wheel and see if one tread slips more than the other. I had this problem myself with the tread slipping after lots of use.
I used a rubber-like coating on the drive wheels to stop the slipping and it has worked great so far. I'm also going to try putting an o-ring over the drive wheel and the non-driving wheel in front of it. My thinking is by putting power to another wheel may help get more traction to the treads. I just need to find an o-ring that is small enough to fit in the groove in the wheels.
As far as motor replacement, if you find a source don't forget to share it with us here. We will all need to replace motors at one point or another.
Old 11-30-2002, 10:35 PM
beetyii's Avatar
beetyii beetyii is offline
Mr. 100%
Hello,
you have to give your motors a run in for two hours.
Solder them out and let them run by 2.4 V. Then solder in again.
Thatīs it.
beetyii
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
Motor current draw findings... neurokinetik XMODS Science 45 01-08-2004 03:42 PM
sbp motor tests w/ results stl2ner XMODS Parts and Hop-Ups 19 12-04-2003 11:08 PM
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 12:58 PM
