Old 11-25-2002, 11:16 PM
Coolmanmj Coolmanmj is offline
Dual Cell kill motrs?
Well i just did a dual cell the thing flies with a 2.6 but i think i killed the 2.6 motor. it still runs but alot slower. Has this happened to ne1 else?i used two nickle metal batteries 150 mAh a peice
Old 11-26-2002, 01:23 AM
DabEAn DabEAn is offline
When do you have this problem? After draining most of the batteries on my dual battery modded bit, it goes into a slower mode of speed. Its kinda weird, all of a sudden its fast, then it goes off to a slow mode. It doesnt seem to kill my motor though, not yet that is...
Old 11-26-2002, 04:50 PM
ya i ran mine for 10-20 mins dual battery and now it went in to a slower mode like you were talking about you know whats up with that?
Old 11-26-2002, 06:06 PM
yea, i think its normal. Cuz 10-20 mins is a long time compared to like 5 or so minutes.
Old 11-26-2002, 10:08 PM
No i meant it ran full speed for 20 mins. Now after full charging the motor is going at lower rpms (probably half) with a 2.6 motor. I did the controller mod too. After a full charge the motor doesn't even have enough torque to move the car. It worked fine for 20 mins going really fast.
Old 11-26-2002, 10:09 PM
I was thinking could it have burned out the circut board?
Old 11-27-2002, 03:48 AM
Stridex's Avatar
Stridex Stridex is offline
Chunk
It's REALLY hard to burn out these motors. Even the generic ones. I've opened a couple up and there's nothing to them. A magnet in the center with coils wrapped around. When I first got a bit clone, I noticed it would go different speeds. The problem was the heatsink was pushing it too hard against the gear or not enough. I only suggest you try that, because I seriously doubt a dual batt config for only 20 minutes can burn them out. If it's still running at that slow speed and you've given it time to cool down, it's not the motor. Maybe one of the batt's is half dead or not getting the same charge as the other one.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 08:42 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 07:12 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 11:23 PM
