11-19-2002, 08:58 PM
abc dtm or mini x??
which one should i buy? there both priced the same,wich ones faster??
11-20-2002, 08:59 AM
let's see,
First of all, I am assuming you have done little to no research on ABC cars. The fourm you choose to put this thread in is for the DTM SP. The SP is the rear wheel drive ABC car.
Again, I am just assuming here BUT you really wanted to compare a 4wd cars to another 4wd car???
Also, please read some of the threads on the X4, I think they will give you a lot of information.
BUT in short, the Mini-X is the size of a Mini-Z (1/28) and the ABC cars (both) are 1/24. They are bigger, bigger wheels tires, turining radius so you need a larger spot to run them in.
They are NOT the same price, the ABC cars come in a kit AND you have to supple the electronics.
-Engineering Manager
11-20-2002, 08:03 PM
could i use my electronics from my 4tec its a futuba 79 mhz..and i got reguler servos and a 17t esc..will these fit in the dtm sp or are they too big?
11-20-2002, 08:04 PM
11-20-2002, 08:06 PM
it was 4 wheel drive...i removed front diffs and belt..its much faster in rwd esp 17t x speed motor
11-21-2002, 06:08 AM
those elcectronics are HUGE, I am thinking no on everything BUT maybe the receiver.
11-21-2002, 04:12 PM
SpeedFreak
i would also have to say no. those electronics are all huge. look into the novak spy, hitec hs-81, and xxl receiver.
11-21-2002, 07:42 PM
ok thx....i'll have to wait a bit then..cant afford new electronics right now....just wanted to slap a kit together and swap electronics back and forth maybe i'll get a tc3 or a rs4
