Old 11-18-2002, 04:02 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Send a message via AIM to ZipRC
[HELP] Installing BC-G Motor in ZZ
Hi, yesterday I went to a hobby shop and picked up a BC-G 2.6 engine for my ZipZap after reading the ZipFAQ and the Compatability Lists.
a. I'm having a sufficient amount of trouble trying to install the lil bugger. I've been readjusting day in and day out, but it just isn't running. Maybe every 1 out of 20 tries it will go forward if I push it, but as soon as I let go of the forward joystick it dies out. Any ideas?
Old 11-18-2002, 09:10 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
The issue is that the zips do not provide enough amps to the bit motors.
Couple of suggestions: All are at your own risk
1)search the message board for PCB Mods
2)buy a cheap clone with the same freq as your zip and swap the pcb's (check that it works with zip controller first)
3) Go get a microsizer.
The PCB swap is my favorite worked great for me.
Hope this helps.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 11-18-2002, 10:09 PM
pt trucker pt trucker is offline
Send a message via AIM to pt trucker
or, do a dual battery mod you can find plenty of threads explaining how to do this.....
pt cruiser
**Work in progress**
-mod'd into a truck -caddy taillights-shaved doors-slammed as low as possible-needs more bodywork and paint
Old 11-19-2002, 01:32 PM
stevensmd3 stevensmd3 is offline
Send a message via AIM to stevensmd3
i am runnin a 3.8 Bc-g motor in my zz and it works great! all i had to do to get it runnin was the no reverse mod.I suggest to just do the no reverse mod
White Skyline
2.6
type 3 suspenion
blue gears
hard ribbed tires
Old 11-19-2002, 03:13 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
hmm i can buy a 20$ car that has a crappy made chassis with stripped out axle holders that i have to disable reverse to obtain faster speeds or i can spend 14$ on a stock bullet clone with almost identical steering and battery life with a more detailed body that will take any motor.
zipzaps are a waste of time if you want it to be fast. why waste all those hours on a 20$ toy that will break eventually anyhow?
Old 11-19-2002, 03:16 PM
ZipRC's Avatar
Modder-Eater
i like to waste time with zipzaps cuz its better than just watching a clone drive in circles. it keeps me busy. i like breaking stuff and fixing it. except when i cant fix it. which is a crapper. anyways, thanks all of u, I most likely plan to switch the PCBs. OogA!
Old 11-19-2002, 03:18 PM
ZipRC's Avatar
Modder-Eater
i like to go backwards! the reason im not doin no reverse is cuz i usually drive my ZZ on tables and stuff. its hard to get around a cup and an edge of a table without goin in reverse! but then again, with a strong enough motor you can probably just crash through.
Old 11-19-2002, 03:37 PM
hogjowlz's Avatar
hmm my clone drives as good if not better than my zipzap did and its a lot lot lot lot faster. i can go in reverse faster than my zipzap could go fwd. the only good thing about zipzaps are the rear axle/gear combos. the green gear is nice.
as far as running on my desk, right out of the box my clone can run over stuff that the zipzap would just stop when it hit it. with the torquey green axle it is just sick. it spins tires on carpet. did i mention wheelies?
PLEASE help with installing FET's and a 5th cell???? DarkPhoenix XMODS 6 04-10-2004 10:06 PM
NiMh installing geofroley Bit Char-G Mods and Projects 4 11-14-2003 04:45 PM
installing a rare earth magnet? LilBitCharged Bit Char-G / MicroSizers 2 01-04-2003 07:36 PM
Installing muffler? MicRoMaN Bit Char-G Parts and Hop-Ups 11 12-07-2002 01:49 PM
