Originally posted by DarthRacer
I'm considering giving up my Micro RS4 in favor of a Mini-Z.
Can anyone give me some good reasons to make the switch?
You may want to cross-post this at Mini-ZRacer.com, but here's some answers:
I like my RS4 for the folowing reasons:
1)Support from HPI and the aftermarket
2)It was in kit form
3)Lexan body
4)Durable - I hit walls in my house all the time
5) can survive parking lot racing
6)uses standard electronics
I dislike my RS4 for the following reason:
1) A little too large to race in my appartment
1) There's lots of support for the Mini-Z from 3rd Parties, as well as Kyosho themselves. Recent developments include the release of Powerline and Mini-ZRacer.com parts which make Mini-Z ownership much less expensive - for example, Kyosho rear shock
springs are $9.49 for 3 little sprigs, while the entire
shock plus springs can be purchased from Mini-ZRacer.com for $3!
2,6) Not much you can do about this, all Mini-Zs are RTR - though this does suggest that maybe you should look at the Tripmate MID which is a kit, for which you can choose the electronics.
3) Mini-ZRacer.com carries lightweight polycarb/lexan shells for the Mini-Z
4) The Z is quite durable in stock form, and can be beefed up w/ alloy parts to cure the weak points.
5) The Z runs great on tennis courts, but for parking lots you'll want to find a very flat area and sweep it before use.
1) You can certainly run a stock Z in your apt. Based on your Micro description, the Z will be about the same speed but will make it around obstacles more easily due to its size. You may want to look at the Epoch for apt. sized racing:
http://tinyrc.com/shop/products.php?pid=6
Overall, it sounds like the Z should be a good fit for you, but also look at the Mini-X and Kawada Tripmate MID for 1/24 scale options, and the Epoch for something a little smaller. All three are available in the Shop:
Hope this helps and don't hesitate to ask any further ?s you have on particular cars!
