Old 07-25-2002, 12:03 AM
EvolutionR28 EvolutionR28 is offline
Body Kits
DOES ANYONE HAVE ANY IDEA HOW TO PUT A BODY KIT ON A BIT CHAR-G???
Old 07-25-2002, 12:14 AM
tinyrc's Avatar
tinyrc tinyrc is offline
EvolutionR28, do you mean make your own? If so, get yourself some styrene sheets and model putty and have at it!
Old 07-25-2002, 01:18 AM
TheFanMan's Avatar
Shoot To ILL
where may one get these things?
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 07-25-2002, 03:23 AM
kbtoyz902's Avatar
Bit OG
id guess a hobby or crafts store perhaps?
Evo, ill go with you to get that stuff cuz i need to buy some to make that custom integra. BTW, im thinking of makin an RSX, instead of a regular integra.
Old 07-25-2002, 11:24 AM
schoon's Avatar
schoon schoon is offline
Send a message via AIM to schoon
Hardware stores often have two part epoxy putty, though depending on the brand, it can be grainy.
I recommend Kneadatite Blue/Yellow epoxy putty, which should be available at any decent hobby store.
Only Milliput (White/Grey) is better for detail, but is more expensive and harder to find.
Old 07-25-2002, 04:08 PM
SSJChar SSJChar is offline
ive heard most gundam modellers say to use tamiya putty, and i tell you, the stuff some of them can scratchbuild is AMAZING.
Old 07-25-2002, 07:59 PM
FunkyMonkey4
Hello, I am a brand new member and am a big fan of Bit Char-g. So about the body kits, how do you make them? I know you just mold it into shapes, but are there any molds or kits that could help construct the shape of the body kit. THX!!!!
Old 07-25-2002, 09:06 PM
DOES ANYONE HAVE A PICTURE OF HOW TO DO THIS???
Old 07-26-2002, 12:38 AM
well using styrene sheets is pretty much like building a shelf outta wood. well i mean thats the way you use styrene sheets. either that way, or stack them in a pile and fuse them together to get a solid piece of styrene, but this is usually dont to make nice long round edges, like if you were making a hand or something. its pretty much sheets of plastic. this would be good for building full bodies, but probably not too good if youre planning on making just a new bumper or something. its also more for advanced ppl. you'd probably want to use putty for this. think of it kinda like clay. usually, you mold some of it to the car in the place that you want it roughly. then when it dries, then you can go at it with sandpaper and such to get the desired shape.
Old 12-20-2002, 06:52 PM
Impreza WR reX's Avatar
Impreza WR reX Impreza WR reX is offline
<(- -)> <- Yoda
There seems to be a good amout of question about body kits on these forums. I just started out my Subaru Rally car replica (my first bit body), and I've decided to make a bit body kit walkthrough/guide. It's gonna take a while to make the car, which I'm using for pictures, so it won't be up for a while , but I use to paint miniatures, so I have some good tricks that will help you all...
stay tuned!
Old 01-13-2003, 06:03 PM
BOme}{_2k5 BOme}{_2k5 is offline
Send a message via AIM to BOme}{_2k5
i know its been a while since the last post but umm.. i tried to put a body kit on my WRX.. it turned out ok but i need better glue.. lol but here it is anywhooo
Old 01-14-2003, 05:02 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
heres just a thought, but you could use that thicker clear plastic cover stock that they use for the covers on reports for making wings/ground efx/spoilers/ or for patching your car back together after it gets stepped on. if you break a fender replace it with this stuff and paint it a different color from the rest of the body...
Old 01-14-2003, 02:02 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
it doesnt even look like its attached...
Old 01-14-2003, 04:09 PM
L3V3L1 L3V3L1 is offline
http://www.tinyrc.com/forums/showthr...ighlight=grond
Old 01-14-2003, 08:17 PM
it is.. the front is loose and i need some better glue haha its just hella low i guess
new xmods and body kits skklown XMODS 21 04-16-2004 07:44 AM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 02:48 PM
How to make body kits (skirts). Bad Company ZipZaps 19 02-05-2004 05:14 PM
Interchangable body kits FLMX647 XMODS Parts and Hop-Ups 7 11-17-2003 05:14 PM
Body Kits ndto Bit Char-G / MicroSizers 2 09-11-2002 04:33 PM
