Old 10-15-2002, 09:02 PM
ChArLeS ChArLeS is offline
super accord
This is a bit char g with a clone body. Has two ni cd batteries with a switch and a 3.8 motor. what do u guys think?
Old 10-15-2002, 09:04 PM
without body
Old 10-15-2002, 10:24 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
kool switch...heh its like a switch for nitrous
Old 10-15-2002, 11:53 PM
pistonhead678 pistonhead678 is offline
thats tight whats the switch for and how do u do that
Old 10-15-2002, 11:56 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Switch doesnt look like its attached to something. That red thing adjacent to is unfamiliar tho.
Old 10-16-2002, 08:05 PM
i got the switch from an old toy of mine. The switch switches the car from one battery to two betteries, so i can race normal of fast.
Old 10-18-2002, 10:38 AM
naseriously's Avatar
naseriously naseriously is offline
switch
where can u find that switch u used to change between 1 & 2 batteries
Old 10-18-2002, 06:35 PM
well i got my switch from an old canned heat, but im sure u could get it from another old toy just lying around
Old 10-21-2002, 09:59 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Awesome job ChArLeS, it looks great!
Old 10-26-2002, 11:30 PM
Arrive2Defy
damn...
Old 10-28-2002, 06:41 PM
JaMeZzZ122 JaMeZzZ122 is offline
Send a message via AIM to JaMeZzZ122
is there a site that shows how to install the switch to the two batteries?
Old 10-30-2002, 09:44 PM
Short1mgb's Avatar
Short1mgb Short1mgb is offline
Lets Play Some Tetris
looks great try getting wings to go over your batery that would look nice and like always if its only for show coil the antenna around a pencil and c how it looks
Old 11-14-2002, 06:43 PM
GT-R RACER GT-R RACER is offline
looks sick but how would I hook the switch and the battery to my car.
PROPS TO THE MICHELIN STICKER
Old 11-14-2002, 09:08 PM
switch
__0__ (suppose to be a pic of the switch)
/ / (the 1 2 3 are suppose to be the 3 metal tabs)
1 2 3 ( the 0 on top is the red thing on the switch)
1.First get a switch similar to mine. you could get one from any old toy with a switch.
2. just like you usaully do for the first step of the two batter mod.
a. take the battery out. then set a wire touching the negative side of the battery.
b. then tape that wire to the battery good so no electricity could get through.
c. put a wire to the metal tab where the negitive part of the battery goes.( best to put it between the chasis and the tab.)
d. then put the battery back in. The wires should now be sticking out.
*******quick check*******
with all the wires sticking out, charge your car. Make sure no wires are touching each other. When u take the car off the charger, and the car responds, you probably need to put more tape on the battery. But if the car doesnt respond AFTER the charge, yout doing fine.
3.solder the first 2 wires.
a. solder the wire from the battery to the "2' part of the switch. (refer to pic)
b.next, solder the wire form the chasis tab to the "1" part of the switch.
put the switch closest to part 1 and 2. charge your car. and try to run it. if it works good job.
then put the switch on the other side. If it DOESNT work, god job.
more instructions later
Old 11-14-2002, 09:10 PM
here is the pic the first one got messed up.
__0__
1 2 3
PLEASE help me: something wrong with the super bits transmitter ilovrc Bit Char-G / MicroSizers 2 02-27-2008 10:39 AM
RCP Bank Turns & NEW SUPER MINI Picutres RCP-Tracks, Inc Tracks 11 01-06-2007 09:51 PM
RCP Tracks Super Mini-96 RCP-Tracks, Inc Tracks 1 06-25-2004 06:13 PM
super bit char-g? big-key Bit Char-G / MicroSizers 7 08-10-2003 12:26 AM
What makes a super bit so super? vtheo Bit Char-G / MicroSizers 8 07-08-2003 11:20 PM
