Old 11-08-2002, 03:36 AM
Clint Clint is offline
Wide Open Throttle
done a few mods.
Mystic purple/green PT
Pro-Stock eclipse(had to shave wheel well...great for carpet)
nubs from a thinkpad+longer antenna+a/c adapter plug(on back)
Another shot of the PT(paint came out very smooth)
Serial Dual 150mA battery mod(under pcb..great for low center of gravity) red motor/green gears
with the dual batt mod the cover will still fit, if i can find it.lol
the car will still charge on the controller, but i wired in a
switching a/c adapter plug and i'm using an 800mA universal
3,4.5,6,7.5,9,12v adapter...using the adapter at 3 volts allows u to use the controller and charger for single batt zz. switching the adapter to 4.5v allows u to charge the dual batts and it still works with the led/timer charging functions.
ZipZaps: (Mustang, PT Cruiser, Porsche, Eclipse,RX-7)
Bit: (Honda Accord, Honda S2000)
MGE: (Diablo)
Old 11-08-2002, 09:31 AM
Wide Open Throttle
Re: whoa the mystic paint!!
Originally posted by brushforhire
hey i love your PT.. where did you get that paint and about how much?? i love that kind of paint.. so freaking awsome.. .. i am so jealous.. LoL...
it's the dupont mirage system..3 cans for 20 bucks.(autozone)
one base flat black...one can that sprays the sparkles on...another can that is clear coat.
first tape off anything u dont want painted...windows,lights..etc
spray the car with 2 light coats of the black base coat.
let it dry. spray very light coats of the sparkle. i did 6 coats, waiting 5 minutes between each coat. then let it dry compltetly..2 hours or so. then spray on a VERY light coat of clear. wait 15 minutes...spray on a little thicker coat of clear. wait an hour..use an exacto knife to get the taped sections off. while the paint is drying, it will be rubbery, so buff it with a tshirt or soft cotton cloth..this will make it very smooth...let it dry overnight...
it is enamel, so it is very durable...
Old 11-08-2002, 10:29 AM
Lordzpider Lordzpider is offline
on the double battery, what is that other battery? and also is it rechargable?
Old 11-08-2002, 11:16 AM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
yup its the same batt as the stock one search the zip zap faq that mattih(sp?) did it has instructions and pics
Old 11-08-2002, 12:18 PM
MICROMAZDA MICROMAZDA is offline
Send a message via Yahoo to MICROMAZDA
I like thee rims
I put the same ones on my pt lastnight. Lowered it and stuck a wing on top. Next I'm gona paint it yellow and shave off the door handles and the mirrors. Gona put little billit mirrors on the top of the door colum insted of the bottom. PIMP BABY!
Old 11-08-2002, 01:29 PM
Wide Open Throttle
these are 150mA and about 2mm shorter than the stock ones..
i get about 15 minutes of high speed runtime with one and a half charges. the batteries dont even get warm.
i have run it for 2 hours straight, run charge run charge etc..with both batteries nothing will fry..the motor doesnt get hot either.
red motor and green gears has a lot of tq and if i use slicks on all fours, it rolls on every corner...so i have medium on the back and a modified stage 3 swaybar up front.
i used to have the resistors jumped..but i felt no gain with it and a single batt and removed it when i went double.
if i didnt have so much fun with my bit char g as well, i would have swapped pcbs...
Old 11-09-2002, 05:30 AM
steve1970's Avatar
steve1970 steve1970 is offline
Destroyer of evil
Thumbs up
I had a similar idea to the pro-stock eclipse...are those back wheels from the Muscle Machines? Was planning to try that with my MS...might not have to shave the wheel wells for that.
LOVE the paint on the PT Cruiser...
Great work, man.
Old 11-09-2002, 05:36 AM
steve1970's Avatar
Destroyer of evil
Thumbs up
Great work, man.
Most Cost Effective Mods rggtm XMODS Parts and Hop-Ups 20 07-01-2004 12:12 AM
Mods For New-bes(and advanced) xmodsman Bit Char-G Mods and Projects 5 01-31-2004 08:18 AM
Look Here For Mods..... MicRoMaN Bit Char-G / MicroSizers 5 01-17-2003 03:51 PM
step by step how to for mods Twistid ZipZaps 2 12-27-2002 03:03 PM
Anyone Found any "Do It Yourself" Mods for ZipZaps? hawks10 Bit Char-G / MicroSizers 6 09-25-2002 11:41 AM
