Old 10-31-2002, 05:12 AM
Zakkorn's Avatar
Zakkorn Zakkorn is offline
Life's a... Bits
Send a message via ICQ to Zakkorn
Unhappy Problems/ Stabilizers and QFM springs
Yesterday I received a pack from QFM that had motors, batteries, gear sets, springs and other bits stuff.
So I said its time for me tor try the new stabilizers.
When I put a stabilizer (either the one with the 4 holes or the other) my bit goes to the left instead of going straight.
Does anyone knows why that happened?
And the other problem is when I tried the springs from QFM the result was that the magnet and the magnet's spring tension weren't enough for the Bit steering.
Do I need stronger magnets (rare earth) and stronger magnet's spring (?) or should I short the suspension springs a little?
-Thanks
  • Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
Old 10-31-2002, 09:08 AM
Barry Barry is offline
You have to cut the springs as they are to long and put to much tension on the steering... Cut little by little until the car turns correctly.
Old 10-31-2002, 09:28 AM
Zakkorn's Avatar
Life's a... Bits
Yes, you are right.
I did that just a while a go and its better.
Also by having that problem I found that one of the two front wheels its about half mm higher than the other.
So probably thats the explanation of why it went left.
Thanks
