10-29-2002, 04:38 PM
Can Zip Zaps use other 27mhz controllers??
Im probably gonna go buy my first mini R/C car this weekend...I think I decided on the Zip Zap at Radio Shack. I've heard some negative things about the controllers being hard to operate due to tiny buttons. I was wondering if I buy a 27mhz car will my controller for my full sized Radio Shack R/C car operate the little Zip Zap??? I realize the Zip Zap controller will still be needed for recharging the car.
10-29-2002, 04:40 PM
hmm, quite possibly. but im not sure. nice idea
~RR~
10-29-2002, 04:55 PM
well im one of the people you have read putting down zipzaps but the controller is pretty nice actually except for the range. that could be the car tho.
10-29-2002, 05:30 PM
Its not the car, its the controler. I get about 5 times the distance using my Microsizer control with my ZipZap. Please note that Reverse and Fordward are backwards using this setup.
10-29-2002, 06:13 PM
Bus Driver!
It possible but what direction will it go?
Like you found out the F/R is reversed for bits-ZZ but for giggles the Toys R Us Special is ok F/R but fliped on L/R
Have not heard of a remove flipping the F/R L/R but that would be fun.
Its possible to put a switch on a remote to "flip" direction or steering. Planing on doing that amd makeing a super controller.
10-29-2002, 09:45 PM
What's funny is I read a review of the Zipzaps vs. Microsizer over at Extremetech.com. Yes, I know it's a computer site and not a R/C site...but Im very into computers and that's how I found out about these little tiny R/C cars. Anyways, they concluded that the ZipZaps controller had a much greater distance than the Microsizer. But if my controller from my regular R/C car works then I'll probably just use that one and use the ZipZap controller as a recharger.
10-30-2002, 01:00 PM
I have a 27 Mhz nakamichi N racer and the controller for that runs my 27 Mhz Zip perfectly. Interestingly enough however my 47 MHZ Micro Sizer controller won't run the same frequency Zip. I suspect it is slight variations on the frequency and that I just got lucky on the 27  Best thing to do would be to just try it and see what happens
10-30-2002, 01:54 PM
The controllers from the Atomic Z cars and the Radio Shack Zip Zaps work the same.
10-30-2002, 02:21 PM
Too Many Hobbies
I have some POS old Radio Shack full size RC, and I think it's 27 MHz (you'd think it would be marked so when someone drags it out of the basement after 2 years that person might remember the frequency, but it's not marked at all). Anyway, it doesn't work with the Zip Zaps. I have a ZZ in both frequencies in fact, and the full size controller wont work with either. your results may vary.
10-30-2002, 05:33 PM
What ever you say Granpa?
Yo Shadoe,
Currently there are no 47 mhz ZZs. Your 47 mhz MS controller won't run either the 49 or 27 mhz ZZ.
10-30-2002, 11:56 PM
I have an HPI RS4 and the 27mhz controller did not work with my ZZ.
