Old 10-28-2002, 09:14 PM
lookatme lookatme is offline
controlers
have you noticed that there are two differant controllers for the zip zaps? i have i have two different ones there is an older models serial model 60-7007 and the new one is 60-7008 the older one it better i think it has molded in bumpy things in he controll sticks and they stick out farther also for easyier use my new controler is harder to keep on the throtle because my fingers slip and there isnt uch to hold on to. Just wantd to fill you guys in on this i thought it was kinda interestin that they have two different styles or it might just be the kit. the 7007 controlercame with a 49mhz pt cruiser and my 49mhz mustang has the smooth ones. You tell me if you have a different controler.
1999 ford cobra mustang
red moter
red transefer gear
red rear axle
no reverse mod
1995 Mitsubishi Eclips GSX Turbo
NOS motor
red/red grearing
no mods.
Old 10-28-2002, 09:15 PM
mjrusso45
any pics?
Old 10-28-2002, 09:26 PM
lnx_author's Avatar
lnx_author lnx_author is offline
Join the GNU Generation!
i'd be interested in seeing the new controller...
i have a [n unspecified] number of zz's but they all have the same controller style AFAIK...
i believe that no matter what controller any new zz has, the joystick mod is a must... (i can't use 'em otherwise)...
Old 10-29-2002, 12:31 AM
Nightwing Nightwing is offline
Bus Driver!
If you dont mind can you read off the FCC ID number of the new one? This would tell if there is any thing different inside.
Old 10-29-2002, 01:39 PM
i will make shure and check the fcc number but i cant get a pick of the sticks because the new one i added some grip to it so my fingers dont slip on it.
red moter
red transefer gear
red rear axle
no reverse mod
NOS motor
red/red grearing
no mods.
Old 10-29-2002, 04:34 PM
EcLiPSe 2.0's Avatar
EcLiPSe 2.0 EcLiPSe 2.0 is offline
Send a message via AIM to EcLiPSe 2.0 Send a message via Yahoo to EcLiPSe 2.0
hmm, i never knew that. thanks!
~RR~
Old 10-29-2002, 04:45 PM
Bus Driver!
It proabbly is the same designed inside. I think the FCC requires a change only if an electronic componet changes from the sample the test was done on. But they could have changed that also.
Old 10-29-2002, 05:44 PM
Kajoq's Avatar
Kajoq Kajoq is offline
4r3 j00 ub3r l337 h4xx0r?
Send a message via AIM to Kajoq
Heres a really bad picture of the new controller, it sticks out about 2-3 millimeters more, and has a roughed up surface on the sticks, its definantly better
Shiggity Shiggity Shwa.
Old 10-29-2002, 05:46 PM
Kajoq's Avatar
Heres another bad picture, this time comparing the controllers...
Old 10-29-2002, 09:43 PM
Kajoq
what serial numbers do you have on yours. my freind just reported to me tht he has a 60-7005 conttroller.
red moter
red transefer gear
red rear axle
no reverse mod
NOS motor
red/red grearing
no mods.
Old 10-29-2002, 09:46 PM
Kajoq's Avatar
The code on the recent 27 with the added knobs is 60-7003, The code on the 49 i have without the good knobs is 60-7007... and right now im not runnin to the baesment to grab my knobless 27 to check it
lol
painted controlers kasper01001 XMODS 22 12-29-2003 08:56 PM
