Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 10-29-2002, 08:30 AM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
Lightbulb Safe 2 Cell mod
this is my 2 cell mod.... it uses the second cell only when going forward( it could be change for revese or both)
the idea was not to hype up the bit-chip to 3v but only the motor
soo if some thing burn it would be the motor, and not the chip
E.E. , if there is any thing wrong with this , holla!!
thanks
rmyc's Avatar
in froward
Old 10-29-2002, 08:31 AM
rmyc's Avatar
in reverse
Old 10-29-2002, 10:58 AM
john john is offline
Too Many Hobbies
that's very interesting, and if it works would come in very handy. I have 2 questions:
Did you try it yet or is this just an idea you came up with?
Is there an easy way to charge the 2nd cell?
This could be a really sweet way to handle a 2 cell mod. I'll be watching this one intently! I don't see any reason why it wouldn't work, other than you're sending a different charge in series through the 2nd batt, but I'd think that it could take it.
Old 10-29-2002, 11:02 AM
Bunta Bunta is offline
Hi rmyc!
I like your idea it is creative.
I have one question for ya,, how do you propose to charge the 2nd battery after it's discharged?
I think that the PCBs can handle a paltry 2.4 volts,, I've heard of some mad scientist who have used 9v and 12v!
good luck and keep coming up with them mods!
-Bunta out
Custom Mods R us
Old 10-29-2002, 01:51 PM
Dayfall Dayfall is offline
Don't forget about the voltage drop across the diodes. I am not an EE mojor, but I have read that there is a 0.7v loss from the average diode. The transistors that run the motor loose about 0.2v each. I think a better way to do it is to find the power leads to the PNP transistors (and their pullup resistors), cut those leads, and run your 3v to them.
Old 10-29-2002, 07:02 PM
rmyc's Avatar
well actually i havent tried it on my bit yet..
..i tried it on another motor and it work fine
i'll probably try it on my bit some time soon, but I DONT KNOW HOW TO SOLDER....lol
..as soon as i learn how to solder i'll do it, or i'll ask a friend.
Old 10-29-2002, 07:07 PM
rmyc's Avatar
Charging
Charging hmmm....i haven't thought about it yet
...well cause they aren't really linked up. you could SOME HOW link them up paralell and double chage em with the stock charger
i'll figure it out sometime , someday
Old 10-30-2002, 09:40 AM
Namuna's Avatar
Namuna Namuna is offline
Old 10-30-2002, 10:56 AM
Too Many Hobbies
What if both batteries where connected in parallel in addition to what you are talking about, but there was a switch to break the connection to the second cell for when it's running?
Wouldn't that effectively let you flip the switch to connect the positive terminals in parallel to charge it, and disconnect the positive terminals (with the switch) when you run it?
Old 10-30-2002, 01:28 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
I've run 6 volts with no issues and flirted with a 12v garage door opener battery for a little bit. No motors burnt out yet, no bits burnt out yet.
Old 10-30-2002, 08:26 PM
GT-ahh GT-ahh is offline
when you connect batteries in parallel it doubles the current not the voltage, so the motor would only be getting 1.5v or whatever.
and also you have to completely flatten both batteries in order to charge them or you get a memory effect, and as both batteries wont go flat at the same time this will be difficult.
btw, has anyone actually fried a circuit or motor from a dual cell mod?
if you dont like my driving, get off the footpath!
Old 10-30-2002, 08:31 PM
sorry to double post but just reviewing your schematic it does not look viable because the second battery has to be earthed to pump voltage into the motor and when you press forward the bit-chip pumps voltage out where youve got the 2nd battery should be earthed. you might even overload the circuit and then youve got one expensive fridge magnet....
Old 10-31-2002, 08:30 AM
rmyc's Avatar
yah that's what i thought about ...
Old 10-31-2002, 08:34 AM
rmyc's Avatar
Originally posted by Namuna
Thanks y'all..it's a big honer for me to be moved to BIT Science.
*sob**sob*
Thanks
safe 3 cell mod? Project RC ZipZaps 2 02-14-2003 10:55 AM
