Go Back   TinyRC.com > 1/24 and Smaller > Mini-Z > Mini-Z - Mini-ZRacer.com
Old 01-31-2009, 11:59 AM
ckybd
Unhappy Mini Z AWD out of control - HELP!
Hi all,
I have 2 AWD Mini Z cars. I haven't run them for a long time, because I have a full-time job and haven't got much time to play with them.
Last evening I finally found some time to run them in my living room.
But while running one of them, I experienced that sometimes it completely goes out of control. Things like: running the motor when I haven't even pull the trigger on my remote control. Also alot of noice came from the servo. This car also has the stacked FETs upgrade (4x2)
Initially I was worried that the receiver on the car was damaged. So I tested my other car (with stock FETs) to see how that one performed. My second car ran a little bit better, but went out of control too from time to time (like running motor a bit without pulling trigger).
What could be the problem?
Is this a problem of the receiver on both my cars or is my remote control just broken?
Please help me.
Yours faithfully,
Ricky
Old 03-25-2009, 10:45 AM
edhchoe edhchoe is offline
There is some radio interference probably. Try running them in a different room...
dNano - Corvette (04/10).
Old 03-25-2009, 12:37 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Ricky, have you tried swapping crystals/transmitters/etc. between the two?
Old 08-12-2009, 03:02 AM
rider66441's Avatar
rider66441 rider66441 is offline
you need to adjust the throttle trim on the remote
Old 08-12-2009, 06:11 AM
mleemor60
The first thing to do would be to replace the transmitter batteries. You did say you hadn't run the cars in a while.
Old 04-27-2010, 03:53 PM
Tommy Dreamer Tommy Dreamer is offline
yeah check batteries and then look at your antenna's
