11-22-2009, 08:35 PM
Originally Posted by XStream
Is there a way to really "reset" the transmitter?
Yes, see page 25 of the manual - push and hold throttle trim down and switch power ON. Continue to hold throttle trim down and confirm the LED lights up after 3 seconds. Release throttle trim.
I had the same problem a few weeks ago. Think that all started because the batteries were somewhat low... i just reset the transmitter and everything went well.
Nuno
11-22-2009, 11:51 PM
Originally Posted by arch2b
if your looking to buy one, make sure you get the kyosho 2.4ghz asf version. the ko version will not work with any kyosho 2.4ghz asf rc's.
wow... that's really confusing  they should fix that yo... as a matter of fact, the one i'm referring may be only available in japan
11-23-2009, 08:14 AM
TinyRC & Mini-zRacer Fan
kyosho decided to use a proprietary 2.4ghz system vs. going with the industry standard used in larger scales. this was a hotly debated issue with the release of the initial line of 2.4 asf mini-z's as many already had 2.4ghz transmitters only to learn they would not work.
if you get a 2.4 module for the ex-10 for example, make sure you get the kyosho 2.4 asf type. the 'for mini-z 2.4ghz' module is the right kind.
11-23-2009, 12:34 PM
Nuno
It is correct that my batteries where quite low, but I've replaced them. But it doesn't even reset. So I guess I have to get them back to the store and wait for a replacement.
