Go Back   TinyRC.com > 1/43 and Smaller > Kyosho dNaNo > Kyosho dNaNo Parts and Hop-Ups
Old 04-18-2009, 06:15 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
Kyosho IC Tag Lap Counter, Home Edition
Does anyone happen to have details on this?
post a link to available information?
Kyosho is selling individual transponders for the Mini-Z already in JPN. Are these compatible with this lap counter?
What is the actual antenna width? Will it fit across a standard RCP 50cm track?
Old 04-18-2009, 06:21 PM
jdob's Avatar
jdob jdob is offline
Hey arch2b - Check this out...
http://www.kyosho.com/eng/support/in...ano/dnano.html
There is a PDF there for the Home Edition...
I just replied to your other post in the NanoTrax-Track Complete thread...I have been seeing these pop up on e-Bay from time to time for around $350 from Japan...
Old 04-19-2009, 08:28 AM
kevtse's Avatar
kevtse kevtse is offline
Been using the home edition for 2 months and it works great. Limit is it only can allow 9 cars at any single time. In the near future Kyosho will have an upgraded software that would allow internet races.
Notice the detector under the RCP on the left of the picture
Old 04-19-2009, 10:28 AM
arch2b's Avatar
thank you for the pictures.
i see from the text on the box that it is rcp compatible;
Compatible to track width up to 970mm. Compatible with 50 size Kyosho (RCP) urethane track
has anyone had the opportunity to try one of the mini-z transponders on this system? also, will they release a seperate mini-z specific software release? seems odd to have 2 versions for seperate scales when one would have sufficed.
also, what exactly is removed from the software in the home edition? i have to assume it has something to do with the online aspect of it, ie; racednano website which is being used by shops at this point.
Old 04-19-2009, 10:31 AM
arch2b's Avatar
thanks. the exact link to the lap timer manual is here.
Old 04-19-2009, 10:33 AM
arch2b's Avatar
for core analog owners, this bit is interesting and a break from our required accessories
*Use a USB cable which is less than 1.5 meters in length with
A - miniB plugs. Reliable data transfer can be affected with
cables longer than 1.5 meters. Also, do not use USB extension
leads.
Old 07-12-2009, 05:45 PM
arch2b's Avatar
just an update, one of these hit ebay today so it's coming!
Item number: 380137722716
$325 + $25 shipping to US.
not bad at all if you ask me.
Old 07-17-2009, 11:28 PM
I got mine from that ebay source two months ago; he puts them up every once and while and yes, it's simple and easy to use.
What I'm curious to know, is if there is any other race management software that is compatible, as the Kyosho software, although very easy to use, is minimalist and limited in options.
Old 07-17-2009, 11:38 PM
arch2b's Avatar
we simply don't know yet. it has not been available to the public long enough for testing to be done.
as soon as flipside racing can get a hold of one or someone can do some port sniffing for them, they are eager to get thier free software compatible.
if you willing to provide some assistance to them, i'm sure they would greatly appreciate it.
Old 07-18-2009, 06:45 PM
..thanks, I will contact flipside ...I've been on his site before and he seems innovative.
Old 08-04-2009, 12:44 PM
arch2b's Avatar
has anyone confirmed what options are available with the home system?
what race management features does it offer, if any?
what limitations does it have? is it a crippled version of the official store/online racing system?
has anyone contacted/assisted flipside racing in port sniffing, etc.?
Old 08-24-2009, 06:03 AM
fraz fraz is offline
ICS Lap Counter Review
OK kids, I broke down and got one so it's time for a real review. FYI, I have been a software developer working in the business for almost 30 years so I'll try not to be too critical For those who are unknowing and who like to speculate if other software will work, please don't. Kyosho is a closed environment and doesn't open their stuff up so others can tweak it. I don't see this changing anytime in the near future so the software they give us is all we get unless we hack it. I saw mention of "flipside" and if somebody could put me in touch I will see what I can help with.
What you get - In the box is the pickup strip, a USB cable, and a CD. Pretty simple software install. Plug in the device to available USB port and immediately tell the Hardware Wizard you will tell where the drivers are located. Point it to the driver directory on the CD, finish the wizard... then do it again for a second time for the serial port driver. Once that is done just run the installer for the lap manager software itself which is pretty straightforward.
Physical installation - There are two boxes on either side of the pickup and they are small but big enough you will have to plan where you are going to put them. If you are using on a Mini-96 RCP system like I am you will have a lot of excess cable from the pickup. You cannot fold it up or stash it and the excess must go to the outside of the track so keep that in mind. Also the little boxes measure roughly 3.75"(l) x 2.25"(w) x .75"(h) and you will need to have one on the infield of the track. That means it will need to be located in the junction where infield curves exist.
Software General - The software is fairly rudimentary and if you've ever gotten used to full featured race management software, you will be disappointed so just get used to it. This software is great and provides the minimal basics but falls way short of being any way to conduct real races.
The absolute worst feature of this software is it's fixed resolution. They claim 1024x768 and even that is incorrect. It looks like you need at least 1200px wide so you can get to the buttons as well. I have it set up on my 1024x600 Asus Eee 901 netbook and it is doable if just running a couple cars but a little bit of a pain. I ended up setting it up on an older laptop so I didn't have to deal with moving the window around for everything I wanted to do.
There is a minimum lap setting, but there is still an issue with it. By default it is set to 2 seconds which is fine but if a car crashes and comes to rest on the line, it will grant a lap to that car every 2 seconds until the car is marshaled. This also means if a driver is running behind they could theoretically cheat by parking on the line and racking up a couple short laps There is really no programmatic way to resolve this problem as the software cannot know one way or another what an intentional or unintentional lap may be. The best way to resolve this is run your track for a while and get an idea of what the fastest lap times are. Then just set the minimum lap time 'somewhat" under to that. Make sure to make it far enough below the fast time to allow for lap time improvements or you will inadvertently drop laps.
The manual mentioned the system's inability to count 2 cars at the same time!! I am assuming this means the exact same time because I tried in vain to get this to fail during my initial testing and got cars within a couple thousandths of a second and the system worked fine. I am kind of ignoring this anyways because in all of my years of professional r/c racing, I have seen ties happen like 2, maybe 3 times ever!
The documentation also mentioned compatibility with IC tags for Mini-Z so it looks like we will get to use those as soon as they become more readily available.
The 9 cars up on screen are great but it sure would be great if this was configurable. As you have seen in the screenshots, each box shows laps, time, and fast lap along with the lap it happened on.
There is also what I consider a pretty nasty bug. The first lap is always counted. In the Free Run mode it doesn't matter, but in the Sprint and Endurance modes, it is a big deal. Yes the partial lap is supposed to get counted towards the total time, but it is usually thrown out and the first time crossing the line that is the trigger for the actual start. It's odd they seem to throw it out for best lap, but they count it as a real lap in the list of laps. This is incorrect. Ether you do both, or not at all.
Reading/Writing IC Data - This part is slick. Place a car on the pickup loop, find an unused car slot from the 9 given, and click "Enter". It reads the original car name which for me was “MAZDA 787B No.55 Le Mans 1991 Winner”. A bit wordy and not matching the body I was running so I changed mine to "Rothmans Porsche 962c" and saved. This is pretty neat because you can embed your name in your IC tag and take to with you to various tracks.
Output Laps to CSV File - While there is not a printing option, at least they let you dump the current output to a CSV file. You can then import to an Excel spreadsheet or if you prefer, a Google Documents spreadsheet. By choosing the latter, you can share with friends
Racing Mode, Free Run - Essentially open practice. Never ending clock so you can test and tune cars and setups. The best way to set up for this setting is to enter all of your cars (I only have 2) and start the clock. That way you can pick up any car, run and test and the laps get recorded without further computer interaction.
Racing Mode, Sprint - In this mode you set a number of laps to reach and all cars race to be the first person to get that number of laps (5 by default). By default it is 5 and I was thinking this might be an interesting way to conduct qualifying. This mode is fairly useless for a single user unless you really wanted to see how fast you can get to a certain amount of laps.
Racing Mode, Endurance - This is the most traditional race mode. With this mode you try to get the most number of laps within the given amount of time. By default it is set to 3 minutes which I think is perfect on our smaller home dNano tracks. Much better than the standard 5 minute qualifiers we run for bigger cars and tracks. Of course it is adjustable so you can make the race duration as long as you want.
Hot Remote Tip - Since I was restricted to placing the pickup loop in one spot of my track room, I started to hate that it was on the other side of the room. Especially since I am in a long knee recovery from my accident. So my trick solution was to set up RDP (Remote Desktop Protocol) and I can remote into my other laptop and run everything from my netbook. Great if you decide to use a desktop to control the hardware but would like to leverage a wireless network and use a laptop to trigger events.
Old 08-24-2009, 12:16 PM
Marcro Marcro is offline
I just have to ask this one question which I am sure is overlooked by most racers, is this hardware/software Mac-compatible? Or will it only work on PC's? How does the system connect to the computer itself? Just a simple USB plug? Most computer's these day's no longer have that serial "printer" port like they did back in the 80's-90's. Can you post pictures of your system set up with your Mini 96? I may get another track some day and it would be nice to have a timing system like this for my Dnano's.
Also, what are the tag's sold for the 1/28 Mini-Z's that will work with this system?
Old 08-24-2009, 12:18 PM
Nice blur's on the track there! Look's like your racing snakes! LOL!
Old 08-24-2009, 12:20 PM
MrNanoTrax's Avatar
Thumbs up
agreed... problems with errors are an issue as well.
this is VERY much a problem... if one car gets stuck or stops on the strip, other passing cars will not get counted. we've had experience with this... often.
hmmm... must not check out nanotrax, we've had them in stock for a month :P
well, i think the fact they throw out the initial lap is to allow for a short lap on the start of the race considering there'll probably be a "grid". this allows the lap to be counted in the total, but not counted as a "fast lap". makes sense to me.
i disagree... sprint mode is good for individual competition. example: if a customer comes in and wants to compete for the the "Sprint Competition" where they compete to see who can record the fastest time running a set number of laps, it gives them something to compete for without having to have other drivers in the shop at the same time.
i definitely agree the software is waaaay too basic and has loooooads of room for improvement. i've already contacted Kyosho directly asking about the next version, they'll let us all know when they've released it.
